Wrong operator in transonic pressure equation? |
June 6, 2011, 08:45 |
Florian Ettner
Rep Power: 17 |
in my transonic simulations with reactingFoam my local continuity errors are far too high (~0.01). I've stumbled upon the pressure equation: After the pEqn is solved, the flux is corrected. In the subsonic case: Code:
if (nonOrth == nNonOrthCorr) { phi += pEqn.flux(); } Code:
if (nonOrth == nNonOrthCorr) { phi == pEqn.flux(); } If not, who can explain it? |
July 10, 2015, 12:07 |
#2 | ||
België/Belgique
Rep Power: 10 |
I know I am replying on an old post, but have you found your answer?
I have a similar doubt with rhoSimpleFoam, where: Quote:
July 11, 2015, 22:16 |
Rep Power: 13 |
Hello Florian,
Note that the method "flux()" is applied over the fvMatrix (pEqn). When solving with the transonic flag in true, the pEqn contains the advective term fvm::div(...). The whole continuity equation is assembled implicity in the pressure equation and then the flux can be calculated with pEqn.flux(). On the other hand, in subsonic cases the advective term is assembled eplicity with fvc::div(phi(or phiHByA)). The last term is not in the pEqn matrix (l.h.s part) and then the advective term must be taken in account to construct the phi flux as phi = phi + pEqn.flux() or phi = phiHByA + pEqn.flux() hope it helps! |
coupling, flux correction, transonic |
Pressure work term in turbulent K.E. equation | lost.identity | Main CFD Forum | 0 | March 8, 2011 12:21 |
Strcture of pressure correction equation in PISO stable over time ? | sebi | Main CFD Forum | 1 | October 26, 2010 22:19 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
pressure Poisson equation in fractinoal step metho | Rui | Main CFD Forum | 6 | October 15, 2000 04:57 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
