kEqn in kEpsilon.C
Old   July 20, 2011, 12:35
Default kEqn in kEpsilon.C
fisch
fisch is on a distinguished road
i try to understand the equations for the k-epsilon turb model.
the equation for k is:
tmp<fvScalarMatrix> kEqn
fvm::ddt(k_)
+ fvm::div(phi_, k_)
- fvm::Sp(fvc::div(phi_), k_)
- fvm::laplacian(DkEff(), k_)
G
- fvm::Sp(epsilon_/k_, k_)
i understand all terms except the second and the third...
As far as i get it these terms should represent div(k*phi)
But how can
+ fvm::div(phi_, k_) - fvm::Sp(fvc::div(phi_), k_) == div(k*phi) ???
Thanks for any advice,
rupert
fisch is offline   Reply With Quote
Old   July 21, 2011, 05:09
Bernhard
Bernhard is on a distinguished road
Be aware, that the term in the original equation is equal to
\vec{U}\cdot\nabla k
which is equal to
\nabla\cdot (k\vec{U}) - k \nabla \cdot \vec{U}
These are the two terms you see in the kEqn. For a converged solution, the second term vanishes (continuity), but it is numerically favorable to keep it while solving the equation.
By the way:
http://www.cfd-online.com/Forums/ope...silon-eqn.html
Bernhard is offline   Reply With Quote
Old   July 22, 2011, 01:21
fisch
Thanks Bernhard,
the mentioned origin term (U * grad(k)) was wrong in some of my books ( it was just div(k * U).
I had right now a look into the "Turbulent Flows" book of Pope and you're right with the origin of the term... So the question is answered.
Thanks again.
rupert
Old   July 22, 2011, 02:53
Bernhard
No, it was nog wrong in the other books, the second term is just zero, since the div(U) = 0
Old   July 22, 2011, 04:30
fisch
thats right.
thanks
Old   July 22, 2011, 09:24
fisch
I had a look on this k-epsilon calculation and wanted to figure out what happens if wall functions are active.
Maybe you know answers to the three following questions, too!?
If i use kqR and epsilon wall functions in my calculations he "updates" this G and forces the values for epsilon on the wall region. He's not touching k, right?
And as far as i get it this "modified" G is used in the k equation at the wall region, too, right?
Is there any documentation about OpenFOAM which formulas were used from the theory (like original equations for kEqn, the wall functions, and so on)???
thanks a lot
rupert
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM Programming & Development 0 March 10, 2011 10:16
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM 0 March 10, 2011 09:58
About devReff() and divDevReff() in kEpsilon.C Zheng.Zhi OpenFOAM 0 August 24, 2009 02:05
Source term divRhoRU tangd OpenFOAM Running, Solving & CFD 2 December 7, 2007 07:54
