lookup a scalar
Old   September 2, 2011, 08:38
Default lookup a scalar
David S
ds-gti is on a distinguished road
I would like to insert a scalar into the for-loop condition which is looked up in any datafile like controlDict or fvSolution.
I tried to use these two examples located in the main funtion of myFoam.C
dictionary outerloop = mesh.solutionDict().subDict("OUTERLOOP");
int nOuterCorr(readInt(outerloop.lookup("nOuterCorrectors")));
//or
scalar mIt = readScalar(solutionDict.lookup("mIt"));
to call it
for (int m=0; m<nOuterCorr; m++)
//or
for (int m=0; m<mIt; m++)
in fvSolution I added:
OUTERLOOP
    nOuterCorrectors 3;
//or
mIt             3;
None of them works, where are I am mistaken?
Thanks for advise!
David
ds-gti is offline   Reply With Quote
Old   September 2, 2011, 10:00
romant's Avatar
Roman Thiele
romant is on a distinguished road
what does not work? do you get an error upon compiling? do you get an error at all? does it run without complaining and just not read the value?
~roman
romant is offline   Reply With Quote
Old   September 5, 2011, 06:44
David S
Thank you for your reply Roman.
It does not read the scalar mIt and in the second case the compiling-report tells: unused parameter nOuterCorr (but it should be used in the for-condition).
Do you use the same or similar code successfully?
Old   September 5, 2011, 06:53
romant's Avatar
Roman Thiele
hej,
if you dfine your scalar before as for example
scalar mIt_;  // in the header
// and then use just
mIt_(outerLoop.lookup("mIt")) ; // in the C file
or just
outerLoop.lookup("mIt") >> mIt ;
~roman
Old   September 5, 2011, 07:13
David S
thank you so much, I will try it!
What is the meaning of the _ (underline) and does the >> perform a shift?
Old   September 5, 2011, 07:15
romant's Avatar
Roman Thiele
underlines like "_" are usually appended to a variable in order to show that we speak about a private variable in a class
the ">>" gives the stream into a variable. It is part of the standard IO package of c++
~roman
Old   September 5, 2011, 07:44
David S
I am sorry, it returns:
TPlusLTest.C: In function âint main(int, char**)â:
TPlusLTest.C:65: error: âmItâ was not declared in this scope
make: *** [Make/linux64GccDPOpt/TPlusLTest.o] Error 1
my corrections:
#include "fvCFD.H"
scalar mIt_;
int main(int argc, char *argv[])
dictionary outerLoop = mesh.solutionDict().subDict("OUTERLOOP");
    outerLoop.lookup("mIt") >> mIt; //line 65!
Did I missunderstood your advise?
Old   September 5, 2011, 07:47
romant's Avatar
Roman Thiele
Originally Posted by ds-gti View Post
TPlusLTest.C:65: error: âouterLoopâ was not declared in this scope
my corrections:
#include "fvCFD.H"
scalar mIt_;
you are missing the underline at all the other parts in the code, either you write the variable with underline or without underline, but don't mix it
~roman
Old   September 5, 2011, 08:21
David S
It works finally, thanks a lot!
Solving for an additional species CO in coalChemistryFoam N. A. OpenFOAM Programming & Development 3 February 18, 2019 05:58
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
Specifying nonuniform boundary condition maka OpenFOAM Running, Solving & CFD 59 October 22, 2014 14:52
Convergence on anisotropic tetahedral meshes pbo OpenFOAM Running, Solving & CFD 12 December 14, 2010 11:59
CFX12 rif errors romance CFX 4 October 26, 2009 13:41
