Cyprien
Rep Power: 18 ![]() |
Hi!
I am facing an issue when I a try to inverse a volTensorField. For example : Code:
volTensorField TM1 = blah blah blah; volTensorField invTM1 = inv(TM1); Do you have any idea to overcome this problem ? Best regards, Cyp |
Kathrin Kissling
Rep Power: 17 ![]() |
Hi Cyp,
can you try the following: Code:
tensorField TM1internal = TM1.internalField(); tensorField invTM1internal = inv(TM1internal); Be aware: A lot of the methods are not available for complete GeometricFields (like your volTensorField) since they could mess with the boundary conditions. Best Kathrin |
Cyprien
Thank for your answer !
In fact the main problem came from a division by zero. Nevertheless, the results are not the one I expected ![]() @+ Cyp |
How to work with constant pressure? | Martin | Siemens | 2 | February 25, 2009 13:23 |
Getting FoamX to work | shaun | OpenFOAM Installation | 12 | March 23, 2007 08:55 |
work related to brake study of a vehical | aero | Siemens | 3 | November 23, 2006 07:43 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
