Rep Power: 15 ![]() |
Hey everyone!
I'm running a self-made solver in parallel and would like to see some interim results in the terminal. Is there a way of using a parallel-Info, so that the output of all processors is written? Thanks in advance! |
Ivor Clifford
Rep Power: 17 ![]() |
If you use Warning instead of Info, then all CPUs will write to the terminal.
Warning << "blah blah" << endl; |
Philip Cardiff
Rep Power: 34 ![]() ![]() |
Or also you can use Pout:
Pout << "blah blah" << endl; |
Thanks a lot for the replies!!
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Parallel efficiency and speedup info | lakeat | OpenFOAM Running, Solving & CFD | 2 | August 31, 2009 11:05 |
OpenFOAM with Cygwin | kitchener | OpenFOAM Installation | 6 | April 24, 2006 23:09 |
want info. of progress in parallel CFD | Hanson Yuan | Main CFD Forum | 1 | June 7, 2003 21:21 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
