A trial of implementing of CVODE as ODESolver
Like Tree2Likes
  • 2 Post By luiscardona
Old   February 11, 2012, 04:06
Default A trial of implementing of CVODE as ODESolver
Aleksey Rukhlenko
Aleksey_R is on a distinguished road
Send a message via ICQ to Aleksey_R
Greetings, dear colleagues.
I tried to implement CVODE solver (from sundials-2.3) as ODESolver in OF-1.6-ext. In CVODE I used backward differencing (BDF). The library compiled successfully but when I try to compile some chemistry solver with BDF support I have an error on linking stage (undefined reference to ODESolver constructor).
I post the code just in case. If someone will handle with the error, I hope, the library could be useful for community.
Best regards, Aleksey.
Aleksey_R is offline   Reply With Quote
Old   February 11, 2012, 15:52
Adhiraj
adhiraj is on a distinguished road
I have incorporated the CVODE stiff ODE solver into the ODESolvers in OpenFOAM 1.7, and it is very similar to your code. (It is based on the sample provided with sundials).
I think you are trying to make the BDF a library separate from the ODE library.
Why is this?
Why don't you add the BDF stuff to the ODESolvers directory,(similar to say RK4, so that under ODESolvers we have ODESolvers, RK,KRR4,SIBS and BDF) as it is based on ODESolver?
Then just edit the file named "files" and add the file $FOAM_SRC/ODE/ODESolvers/BDF/BDF.C" ?
Last edited by adhiraj; February 11, 2012 at 15:54. Reason: explained more clearly
adhiraj is offline   Reply With Quote
Old   February 11, 2012, 16:30
Aleksey Rukhlenko
I tried to copy BDF to ODESolvers folder (which contains KRR4, SIBS, RK) and I've got the same result - the library libODE compiled successfully but when I tried to compile any solver I got an error on linking stage.
Old   February 11, 2012, 18:48
Adhiraj
Try putting the BDF under the ODESolvers directory, and remove the Make directory under BDF.
Edit the Make directory of ODE to add entries for BDF.
This means that there will only be one library built, and that will have SIBS+RK+BDF+KRR4, all selectable at runtime.
Old   February 12, 2012, 07:17
Aleksey Rukhlenko
Thank you for advise. I did it. And the compilation of libODE was successful, but the compilation of solvers wasn't. The same error on linking stage - undefined reference to ODESolver constructor.
Anyway, I managed to use CVODE in OpenFoam without using ODESolver.
Old   February 12, 2012, 09:50
Adhiraj
I am a bit confused now; what solver are you trying to build? Did you specify the libODE for each solver's Make directory?
Old   February 14, 2012, 16:12
Joseph Urich
jurich is on a distinguished road
Aleksey,
I've been looking into implementing CVODE or LSODE in OF 2.0.x, and came across your post. In yours, the line in BDF.C:
f_data = new BDF(*this);
tries to implement BDF using a copy constructor, which you didn't implement. That should be why the linker complains "undefined reference to ODESolver constructor" when you try to build an application.
I think you should just be able to use:
f_data = this;
to get it working, but haven't tried it (I'm not running 1.6ext at the moment).
Also, I hope you're aware of alternateChemistryModel, which implements Cantera and sundials/cvode? If not, it might be worth looking for.
Regards.
jurich is offline   Reply With Quote
Old   February 14, 2012, 16:43
Adhiraj
Originally Posted by jurich View Post
Aleksey,
f_data = this;
Regards.
I am not sure of this. I have the same kind of new statement in my implementation and I get no errors, and the results also seem good.
Also, the error is about the ODESolver constructor, not the BDF constructor.
Old   April 14, 2012, 03:59
Luis Cardona
luiscardona is on a distinguished road
Dear foamers,
After many failed attempts, I finally managed to implement BDF (CVODE solver) in OF-1.7.1 selectable at runTime like SIBS, RK and KRR4 based on the code posted before by Aleksey_R.
In order to use it please take into account that in the chemistryProperties dictionary in constant folder, you must set the inverse of eps (for example 20 for a eps of 0.05) so in ODESolver.C file the whole time step can be sent to CVODE solver. This happens because CVODE has its own way to calculate internal time step, so OpenFOAM time stepping routine must be overridden somehow. It is probably not the best way to achieve it... but it works!
In order to install this library just merge the content of the attached file the src/ODE folder and recompile using wmake libso. It is known to work with sundials 2.3.0 (the instructions about compiling sundials can be easily found in the forum)- In my case, I installed sundials on home folder-
Please try the solver and make your own tests (for example running ODETest app). So far in my tests, SIBS seems to be faster for my problem (chemical kinetics). Also if you can make a better-cleaner version of this solver, you can upload it and share it back with the community.
JBUNSW and randolph like this.
luiscardona is offline   Reply With Quote
Old   April 14, 2012, 09:37
Adhiraj
I override that by specifying the initial chemical time scale as unity in the chemistryProperties file.
That is consistent with my observations. But for some problems SIBS crashes while solving the ODE.
Old   February 27, 2014, 05:00
James Behzadi
JBUNSW is on a distinguished road
Dear all,
I implemented SUNDIALS CVODE 2.7 in OpenFOAM 2.0.x. I pretty much followed the instructions given at this thread. However, my implementation is very slow when I use the built-in numerical jacobian feature of CVODE. I have explained the details here.
Any help is highly appreciated.
Jalal
JBUNSW is offline   Reply With Quote
Old   March 6, 2014, 19:53
James Behzadi
Old   September 8, 2020, 23:32
Reviewer #2
randolph is on a distinguished road
Originally Posted by luiscardona View Post
Dear foamers,
Luis,
Can CVODE handle fractional exponent reaction?
Thanks,
Rdf
randolph is offline   Reply With Quote
cvode, odesolver, sundials
OpenFOAM 1.7 and CVODE adhiraj OpenFOAM 6 May 22, 2011 00:01
Problem implementing CVODE ODE solver markusrehm OpenFOAM 20 October 13, 2010 17:02
CVODE Error message Robert FLUENT 2 February 12, 2003 18:28
