Marwan Sabih
Rep Power: 15 ![]() |
Here is a dropbox-link
http://dl.dropbox.com/u/68764461/channelAnalyser.zip Hello OpenFoamers, (hope this is the right place for this post ) for my Diplomthesis i'm writing a small python-Programm to analyse Channel-Flows with OpenFoam - it's specialized in LES and in German, but i'm going to write an english readme - if someone is interested. If you start the programm (python worker.py)(no python3) (if you want you should install somethings first, which i tell you later) /________________________Hauptmenü_________________ __________/ Zum Beenden: quit Für neuen Fall: new Für alten Fall: old Für analogen Fall: ana Re in R_tau umwandeln: re You can choose between new - to set up a new Case 1. Specify the model (all ScaleSimilarity models will not work at this stage - i will have to ask my professor first if i can publish them here) 2. choose the dimensions (x,y,z) of the channel 3. Specify the Reynoldsnumber correspondend to Re_0 of the laminar case - later on perturbU (that i found here will automatic create a new starting Field) 4. next choose the number of cellpoints in (x,y,z) direction. Based on Re_tau the Programm will make an sugastion After this you enter the working mode - which will be discussed later If you choose old: you will simply be able to work on an old case again If you choose ana: you create a new case analog to some Reynoldsnumber but with a new LES modell - the last Field of the case you specify will be mapped into the Channel After you finished one of the steps before you're now in working mode: __________________________________________________ ___________ /_____________________Allgemeine Befehle_____________________/ Zum Beenden: quit Systembefehl eingeben: sys Fall wechseln: break Informationen zum aktuellen Fall: info (ausführliche Informationen zum aktuellen Fall: ainfo ) Diese Menü einblenden: help Befehlsmenü ein und ausblenden: bm __________________________________________________ ___________ /________________Fall Vor- und Nachbereiten__________________/ Berechnung starten: run parallele Berechnung starten: prun Anzahl der Kerne für parallele Berechnung ändern: chc Daten aus paralleler Rechnung zusammenführen: rec Re_tau manuell setzen: mset Re_tau auf letztes Rechenergebnis setzen: set Rechenfortschritt zeigen: show Berechnung abbrechen: stop Startzeit setzen: start Startzeit auf letzte berechnete Zeit setzen: last Endzeit setzen: end delta T umstellen: delta writeInterval umstellen: wi Zeitmittelung ein- und ausschalten: ava ParaView starten: bild __________________________________________________ ___________ /_________________________Plotten__________________ __________/ Namen von Fällen ändern: cnames Festlegen welche Fälle im Plot zu sehen sind: cfalls Plots als Png speichern: png U_Mean zeigen: su <u,u>/u_t^2 zeigen: suu <v,v>/u_t^2 zeigen: svv <w,w>/u_t^2 zeigen: sww <u,v>/u_t^2 zeigen: suv normierte kinetische Energie zeigen: sk nom. Geschwindigkeit in einem Punkt über Zeit: pu Fouriertransformierte von U_Mean in einem Punkt: ft Fouriertransformation über Ebene von U_Mean: rft __________________________________________________ ___________ /___________________Physikalische Größen_____________________/ Für nu: nu Für vorgebenes u_tau: vut Für berechnetes u_tau: ut Für berechnetes Re_tau: ret The most usefull commands maybe: run - to start the simulation start - to specify the starttime end - to specify the endtime last - to set the starttime to the latest time calculatet stop - to finish the simulation prun - to run in parallel chc - to change the number of cores to use for a parallel run rec - to reconstruct parallel data (you need to to this if you run in parallel later use last) wi - to change the timesteps used in the simulation help - to get the help menu ava - to start or end avaraging su - (you need have avaraged before) will show you the mean profile suu - will show you the reynoldstresses ft - is a bit more tricky and creates a spectrum in time of a point of the channelflow : 1. you specify the time from where you want to to start 2. you specify the number of timesteps you want to use for the spectrum 3. you sepcify how often you shift the intervall for one timestep - over all resulting Spectra will be avaraged (all images will be safed at the plot folder in subfolders) info - gives information to the case you're working with So if you want to use it, you need to install somethings first. 1.go in the subfolder daten and run wmake libso 2. go in channelDNS and run wmake 3. go in channelPlanes and run wmake 4. go in perturbU and again wmake Feedback is welcome anytime but unfortunately i don't have too much time so i can not promise change something. Maybe for some it will help a bit. Best regards LeFrog |
channelflow les |
