April 4, 2012, 12:49 |
Deep modification of turbulence model
Pablo Higuera
Rep Power: 19 |
I am currently working in porous media flow with free surface using a customized interFoam (OF2.1.0). So far the model has proven to be stable, but it runs for laminar turbulence model. Now I have to modify kEpsilon to add the closure terms needed. In order to do so I have to make kEpsilon to accept another field (porosity) at the time of creation, but that is kind of a secondary question for now. As a first step I am trying to eliminate the unwanted functions e.g. R(), as I will only be using the model for myInterFoam. I changed the name of the model to kEpsilonPor and it compiles flawlessly. Then I removed all the references to R() in kEpsilonPor.H and kEpsilonPor.C and it did not compile. To proceed I changed "files" and "options" from Make folder: files Code:
kEpsilonPor.C LIB = $(FOAM_USER_LIBBIN)/libPorousRASModels Code:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude LIB_LIBS = \ -lincompressibleTurbulenceModel \ -lfiniteVolume \ -lmeshTools Everything compiles well, getting rid of the mentioned references to R() in RASModel.C, RASModel.H and turbulenceModel.H. The problem is that when I run any case using the new turbulence model I keep getting: Code:
kEpsilonPorCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Any hints on what could be happening and how to fix it? Thanks Pablo |
April 9, 2012, 05:57 |
Pablo Higuera
Rep Power: 19 |
January 29, 2013, 10:18 |
Hi everybody
In the createFields of my solver I create a pointer on an RASModel named turbulence (same as for example in the createFields of simpleFoam). My problem is that I would like to access the name of the turbulence model. I'm using OF2.1.x. In other versions this was possible with turbulence->typeModel() but this is no more available. Do you have any suggestions? Thanks in advance |
openfoam, turbulence model |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 13:54 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Turbulence Model Modification and Implement | qtian | OpenFOAM Running, Solving & CFD | 1 | January 25, 2009 06:53 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
