Polynomial density and transport properties in buoyantBoussinesqSimpleFoam
Like Tree12Likes
Old   March 10, 2014, 11:57
anshul bansal
anshul bansal is on a distinguished road
thanks olivier ..
anshul bansal is offline   Reply With Quote
Old   May 2, 2014, 11:32
Default icoPolynomial: chtMultiRegionSimpleFoam
  #22
Vitor Vasconcelos
vitors is on a distinguished road
I am running a simulation with chtMultiRegionSimpleFoam which, apparently, runs ok. It has three solids and one fluid, namely, water.
I set water properties in my thermophysicalProperties files and it works fine for rhoConst. When I tried to use icoPolynomial for equationOfState (and the respective changes in the heRhoThemo type) I could and the four polynomials without issues.
However, and simulating I realized the fluid density never changes. The only way I got a variation in the fluid density was using a PerfectFluid in equationOfState.
I'm using OpenFOAM 2.2.0.
My themophysicalProperties file for fluid is:
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleEnthalpy;
dpdt            no;
// Cooler - water
// Data from H2O_NIST
// Values for 590 < T < 619 (K)
// Data for viscosity (mu), kappa, Cp and rho were fitted for polynomials
// of 6th order.
mixture
    specie
        // Water mol weight [g/mol]
        nMoles          1;
        molWeight       18.02;
    transport
      // *** polynomial
      // mu [Pa.s]
      // kappa [W/m/K]
     muCoeffs<8> (0.477756 -0.00337294 7.80884e-06 -2.59645e-09 -1.64495e-11 2.49614e-14 -1.10764e-17 0);
     kappaCoeffs<8> (1456.92 -10.2864 0.0238197 -7.80437e-06 -5.02923e-08 7.60632e-11 -3.36662e-14 0);
    thermodynamics
      // *** hPolynomial
      // Cp = [J/kg/K]
      Hf  0;
      Sf  0;
      CpCoeffs<8> (-7.56975e08 5.24432e06 -11530.9 1.22828 0.0308639 -4.34995e-05 1.88346e-08 0);
    equationOfState
      // *** icoPolynomial
      // rho = [Kg/m^3]
      rhoCoeffs<8> (4.02745e06 -27520.6 57.8951 0.00610405 -0.000187407 2.52756e-07 -1.08057e-10 0);
Any suggestions on how effectivelly use icoPolynomial for water?
Thank you in advance.
Vitor
vitors is offline   Reply With Quote
Old   May 16, 2014, 07:15
Evgeny
karaul is on a distinguished road
Check fvSolution for water
it has probably rhomin and rhomax like (my example)
SIMPLE
momentumPredictor on;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 100000;
rhoMin rhoMin [1 -3 0 0 0] 1000;
rhoMax rhoMax [1 -3 0 0 0] 3000;
strato likes this.
karaul is offline   Reply With Quote
Old   May 16, 2014, 11:10
Vitor Vasconcelos
Bull's eye Evgeny, thanks. After playing with fvSolution I realized that my densities are
far too high and they were bounded by the values in fvSolution.
Now I can focus in the real problem: why the densities are too high.
Thank you very much.
Vitor
Old   June 16, 2015, 22:31
Ting
tbao is on a distinguished road
Originally Posted by Nikunj.R View Post
Hey!
I figured how to relax T and rho. This works fine when I am using rho, which is lineraly dependen on Temperature.
However, when I am using the following dependence of rho on T (rho = 4.8611E-10(T^6) - 9.8744E-07(T^5) + 8.3490E-04(T^4) - 3.7610E-01(T^3) + 9.5196E+01(T^2) - 1.2836E+04(T) + 7.2132E+05), I am getting the following error:
Courant Number mean: 8.34989e-07 max: 1.49846e-06
deltaT = 0.00172794
Time = 0.0043679
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 0.358751, Final residual = 8.38803e-08, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.687432, Final residual = 6.84879e-08, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.359104, Final residual = 8.25799e-08, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 1.17068e-07, No Iterations 2
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Foam::specieThermo<Foam::hPolynomialThermo<Foam::i coPolynomial<8>, 8> >::T(double, double, double (Foam::specieThermo<Foam::hPolynomialThermo<Foam:: icoPolynomial<8>, 8> >::*)(double) const, double (Foam::specieThermo<Foam::hPolynomialThermo<Foam:: icoPolynomial<8>, 8> >::*)(double) const, double (Foam::specieThermo<Foam::hPolynomialThermo<Foam:: icoPolynomial<8>, 8> >::*)(double) const) const in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
#3 Foam::hRhoThermo<Foam:ureMixture<Foam:olynomia lTransport<Foam::specieThermo<Foam::hPolynomialThe rmo<Foam::icoPolynomial<8>, 8> >, 8> > >::calculate() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hRhoThermo<Foam:ureMixture<Foam:olynomia lTransport<Foam::specieThermo<Foam::hPolynomialThe rmo<Foam::icoPolynomial<8>, 8> >, 8> > >::correct() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/buoyantPimpleFoam"
#6 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Aborted (core dumped)
As apparent by the courant number, the problem is not with the convergence now, it is with something else.
Attached with this post are all the files I used for the analysis.
Thanks for you help!
Hi Nikunj,
I meet the same problem. Could you tell the detail how did you figure out relaxing T and rho. I used chtmultiregionFoam. Thanks for your help.
tbao is offline   Reply With Quote
Old   June 16, 2015, 23:48
Ting
Originally Posted by olivierG View Post
hello,
Your Co number is too high.
When using variable properties with T, you should take care that T can for some iterations get some bad value, like very cold / hot -> then your density goes wrong -> velocity goes wrong -> high courant number and crash.
The solution is: relax T / rho much more, and use first order for velocity at the beginning.
NB: There where a feature bug some time ago about adding temperature limiter, and i don't know if this is implemented actually, but this is not so difficult to add this.
regards,
olivier
Hi Olivier,
I used icoPolynomial in chtmultiregionfoma and I got very high Co number for water, os it was not converged. I think your explanation to this problem is pretty right, unfortunately I am a new foamer so I quite don't know how to fix this problem. You said that the solution is to relax T and rho, could you please tell me the detail or give me some hint to fix my problem. Thanks in advance.
Old   September 21, 2016, 13:56
Praveen Srikanth
praveensrikanth91 is on a distinguished road
Originally Posted by tbao View Post
Hi Olivier,
Hey,
I was wondering if you found a solution to this problem. I am facing a similar problem with my closed liquid domain where the Co blows up. I tried relaxing the solution and that did not help at all.
Any help is appreciated
Thank you so much
praveensrikanth91 is offline   Reply With Quote
Old   September 21, 2016, 14:23
Ting
Originally Posted by praveensrikanth91 View Post
Hey,
Thank you so much
I did not solve this problem. Instead, I modified cht solver for my purpose. Good luck
Old   September 26, 2016, 20:22
Praveen Srikanth
Thank you so much for the reply tbao. That is unfortunate though. I was hoping to find out a solution here. Hope someone else who faced a similar issue would be able to help
Praveen
Old   November 16, 2016, 02:33
chengan.wang
wangchengan2003 is on a distinguished road
Send a message via Skype™ to wangchengan2003
Dear Olivier
I want to know set the polynomial properties in other solvers? For example, in IcoFoam, PimpleDymFoam, etc?
Best regards
wangchengan2003 is offline   Reply With Quote
Passive scalar transport novyno OpenFOAM Running, Solving & CFD 10 May 5, 2016 13:31
icoPoly8ThermoPhysics limits density below 2 kg/m3 smajer OpenFOAM 2 March 16, 2012 06:11
Questions for a species transport problems (snapshots attached) aleisia FLUENT 2 October 9, 2011 04:40
unsteady solver and density method Ellen FLUENT 0 December 23, 2008 14:25
UDF to change density in species transport Karthik FLUENT 6 December 8, 2004 18:19
