outflow boundar condition problem, mutiphase flow
Old   April 29, 2012, 14:11
Default outflow boundar condition problem, mutiphase flow
Mieszko Młody
ziemowitzima is on a distinguished road
I am doing some multiphase flow computations using twoLiquidMixigFoam solver.
Simulation (see attached figure:
calculates flow with inflow (emergency valves inflow of the fluid1 to the tunnel filled with fluid2 ) and outfolw from the tunnel.
After fluid1 reaches end of the tunnel a problem appears. Because there is a "recirculation zone" trying to leave the tunnel , imposed boundary conditions does not allow it to leave the computational domain, see attached next 3 figures for different time :
I was trying many different BC for velocity (zeroGradient, InletOutlet, mixedDirections) but result/problem is the same...
Does any one know if there is some simple (or any using proper BC) solution for this problem ? To just allow fluid to leave domain, without doing mass at the outflow ??
Best
ziemowitzima is offline   Reply With Quote
Old   April 29, 2012, 14:27
Mieszko Młody
interesting is , that after setting (gravity) g = 0, problem disappears ...
boundary condition, multiphase flow, outflow
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Fixed Flow rate and outlet Continuity Problem mrshb4 OpenFOAM 1 March 10, 2012 14:32
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
Flow not moving - Supersonic/Initial Pressure problem? shankara.2 FLUENT 0 June 9, 2009 20:49
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
