Independent meshes with interDyMFoam
Old   April 30, 2012, 15:16
Default Independent meshes with interDyMFoam
angel
anmartin is on a distinguished road
I would like to know if it is possible to simulate fluid sloshing with interdymfoam using several independent tanks (meshes). I have tried it separately and all of them works but when i try to simulate alltogether ( mergemeshes) fail.
Regards
anmartin is offline   Reply With Quote
Old   January 28, 2013, 11:45
elliot_hfx is on a distinguished road
Regards
I meet similar problems as you described. Did you solve the problem? Or do you know how to
simulate several independent tanks using interDyMFoam?
Thanks.
Best,
Elliot
elliot_hfx is offline   Reply With Quote
Old   January 28, 2013, 12:44
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Does mergemeshes fail, or does the simulation fail?
mturcios777 is offline   Reply With Quote
Old   January 28, 2013, 12:50
Yes, the merged meshes failed. The time step become small and small as the simulation proceeds and it fails in 0.5 simulation time.
I was trying to simulate two tanks sloshing at the same time.
Do you have any suggestions?
Thanks.
Elliot
Old   January 28, 2013, 12:51
Do you mean I need to merge the mesh of two tanks first?
Thanks.
Elliot
Old   January 28, 2013, 12:53
Marco A. Turcios
What I was wondering is if the mergeMeshes utility failed or if the solver failed. Judging from your comment about, I assume that mergeMeshes works but your solver crashes.
Old   January 28, 2013, 14:24
angel
In my case I import the mesh using front other software and I was imposible to me run the case. The solver fail
If the meshes share some elements I think it would be possible
Regards
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
HELP!! How could I obtain structured-orthogonal-body fitted meshes???? DajeMoo ANSYS 0 January 28, 2011 12:52
interDyMFoam with GGI in 3d stawrogin OpenFOAM Running, Solving & CFD 2 January 5, 2011 02:17
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 13:21
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
