April 30, 2012, 15:16 |
Independent meshes with interDyMFoam
angel
I would like to know if it is possible to simulate fluid sloshing with interdymfoam using several independent tanks (meshes). I have tried it separately and all of them works but when i try to simulate alltogether ( mergemeshes) fail. Regards |
January 28, 2013, 11:45 |
#2 | |
I meet similar problems as you described. Did you solve the problem? Or do you know how to simulate several independent tanks using interDyMFoam? Thanks. Best, Elliot |
January 28, 2013, 12:44 |
Marco A. Turcios
Rep Power: 28 |
Does mergemeshes fail, or does the simulation fail?
January 28, 2013, 12:50 |
Yes, the merged meshes failed. The time step become small and small as the simulation proceeds and it fails in 0.5 simulation time.
I was trying to simulate two tanks sloshing at the same time. Do you have any suggestions? Thanks. Elliot |
January 28, 2013, 12:51 |
Do you mean I need to merge the mesh of two tanks first?
Thanks. Elliot |
January 28, 2013, 12:53 |
Marco A. Turcios
Rep Power: 28 |
What I was wondering is if the mergeMeshes utility failed or if the solver failed. Judging from your comment about, I assume that mergeMeshes works but your solver crashes.
January 28, 2013, 14:24 |
angel
In my case I import the mesh using front other software and I was imposible to me run the case. The solver fail If the meshes share some elements I think it would be possible Regards |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
HELP!! How could I obtain structured-orthogonal-body fitted meshes???? | DajeMoo | ANSYS | 0 | January 28, 2011 12:52 |
interDyMFoam with GGI in 3d | stawrogin | OpenFOAM Running, Solving & CFD | 2 | January 5, 2011 02:17 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
Large 3D tetrahedral meshes | Aldo Bonfiglioli | Main CFD Forum | 4 | August 27, 1999 03:33 |
