Everything you need to compute DNS in channel vs OF 2.1.0
Like Tree28Likes
Old   May 6, 2012, 02:39
Default Everything you need to compute DNS in channel vs OF 2.1.0
Lev
levka is on a distinguished road
Hello everyone.
Here are everything you need to compute DNS in channel vs OF 2.1.
Attached pdf is comparison this solver with DNS data of Kawamura and "Kim and Moin, 1987". Max divergence by mean "u" vs Moin is 2%, vs Kawamura 0%. Also in pdf there is view of full turbulent velocity profile that was taken during average procedure(10,000-30,000).
Following reference is to download zip file:
http://www.sendspace.com/file/xw4myd
Zip contains:
- solver (modified ico_Foam);
- utility to create tangential mesh spacing;
- test case with perturbed initial data;
- computed averaged data+log file;
- manipulation with data Excel file;
- paper Kim and Moin 1987;
- DNS data from paper above;
- DNS data Kawamura;
- master thesis of Steven van Haren"Testing DNS capability of OpenFOAM
and STAR-CCM+";
In case zip is not available i will e-mail it .
Have fun guys!
levka is offline   Reply With Quote
Old   May 7, 2012, 11:22
Goutam Saha
Goutam is on a distinguished road
Thanks for your contribution. What about LES for a pipe flow?
Goutam is offline   Reply With Quote
Old   May 7, 2012, 16:18
Alberto Passalacqua
You might want to consider to submit this validation study to the Foundation, once they will start accepting code and contributions. It is surely valuable.
Alberto Passalacqua
Old   May 8, 2012, 02:40
Default nice
Lev
Nice idea! But how to do it ?
Old   May 8, 2012, 02:46
Alberto Passalacqua
There is no defined procedure yet. When I tried to submit some code I used OpenCFD mantis, and they said they are defining the rules for contributors, and will contact me when ready. Maybe you could ask them if they are interested also in validation studies.
Alberto Passalacqua
Old   May 23, 2012, 14:54
Default DNS and Airfoil
Ehsan
ehsan is on a distinguished road
Dear all
Could someone help me in taking a test of DNS over airfoil?
Thanks
ehsan is offline   Reply With Quote
Old   May 24, 2012, 02:02
Default ...
Lev
Hello ehsan,
I suggest you to download solver solver from the first post and utilize that for your purpose. Just change mesh and BC according to your case, not forget to use initial conditions with perturbations( you can map them from my case to yours using mapField utility). And enjoy. Be in touch. I am interesting in the results.
songwukong likes this.
Old   May 24, 2012, 02:32
Ehsan
Dear Levka
Thanks a lot, we will work on this topic and will be in touch. However, does 2D DNS solution is very time consuming?
Regards
Ehsan
Old   May 24, 2012, 03:54
Default ...
Lev
Originally Posted by ehsan View Post
Dear Levka
Regards
Ehsan
That depends on your mesh and mesh it self should be defined according to comparison some integral parameter (for example U+ profile or Cf, Cd ) with some closest benchmark problem. Got it?
Cheers
Old   May 24, 2012, 04:58
Ehsan
Dear Levka
In fact, I recently saw this paper:
http://www.sciencedirect.com/science...45793004001203
where the flow simulation over two dimensional and three dimensional airfoil had been reported, in Fig. 7 the U velocity had been reported and we will try to compare our results with this paper.
In fact, I am not familiar with DNS at all while I had worked on LES before, so it took me some time to understand DNS. I downloaded the file you prepared and work on it now.
Regards and thanks
Ehsan
Old   May 26, 2012, 15:34
Default Run b y using dnsFoam
  #11
Farshad Rezaei
Farshad585 is on a distinguished road
Hi everybody
I want to simulate an airfoil and analyze it by dnsFoam. I've used boundary condition as it is in incompressible/simplefoam/2Dairfoil
I've started to run by dnsFoam, but there are the below errors:
--> FOAM FATAL ERROR:
calculated number of cells is incorrect
From function Kmesh::Kmesh(const fvMesh& mesh)
in file Kmesh/Kmesh.C at line 84.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Foam::Kmesh::Kmesh(Foam::fvMesh const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/librandomProcesses.so"
in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/dnsFoam"
#4 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Aborted
Could anybody help me what should I do?
Farshad585 is offline   Reply With Quote
Old   May 28, 2012, 10:08
Default ....
  #12
Lev
Hello,Farshad585
that error maybe coursed by either you did not run blockmesh, either your initial field is generated not for your mesh.
Best
Originally Posted by Farshad585 View Post
Hi everybody
FOAM aborting
Aborted
Farshad585 likes this.
Old   May 28, 2012, 18:38
Farshad Rezaei
Originally Posted by levka View Post
Hello,Farshad585
Best
Thanks a lot
Old   November 13, 2012, 09:30
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi levka,
Could you explain how to proceed with the zip file you made available in order to build the ico_DNS and run it, please?
thanks!
aerospain is offline   Reply With Quote
Old   December 26, 2012, 05:56
Default least sqaures & fourth order
  #15
Farshad Rezaei
Hi everybody
I've used least squares and fourth order for discretization for pressure gradient (grad(p)), but I don't know the performance of least sqaures and fourth order. Could somebody give me some information about it?
regards
Old   June 21, 2013, 06:07
student_07 is on a distinguished road
Hallo Levka,
I have one question to your solver. I'm still a beginner to OpenFoam, so don't wonder, if it is obvious to you.
I ran the test file and it works fine. Now I want to modify it and want to use a constant inlet velocity as boundry condition. In "constant/transportProperties" you set a pressure gradient "gradP". But there is also a "transportProperties_channel" file in which U_bar (probably an average velocity) can be set instead of the pressure gradient.
How do I have to change the solver to use a constant inlet velocity? When I just use Ubar, OpenFoam still requires a pressure gradient?
Regards,
Klaus
student_07 is offline   Reply With Quote
Old   June 21, 2013, 14:09
Farshad Rezaei
Originally Posted by student_07 View Post
Hallo Levka,
Regards,
Klaus
hi
you shoul go to system/fvscheme and set pressure gradient as it show gradP
Old   June 21, 2013, 14:10
Farshad Rezaei
hi
Old   June 23, 2013, 07:16
Lev
I suggest you to look at regular channel solver and it's tutorial. "Ubar" is used over there without any gradP.
Old   July 9, 2013, 05:18
lixx is on a distinguished road
Nice work!
In the test folder, I can not find the 0/ folder. So you just started from a precursor run or else?
Hello everyone.
Zip contains:
and STAR-CCM+";
Have fun guys!
Farshad585 and vb276 like this.
lixx is offline   Reply With Quote
Channel flow DNS alberto OpenFOAM Running, Solving & CFD 20 February 17, 2016 17:26
DNS data of Jimenez et al. for turbulent channel flow @ Ret = 2000 sbaffini Main CFD Forum 2 July 29, 2013 06:03
Channel flow DNS Abhinav Main CFD Forum 1 April 11, 2013 06:37
DNS: how to compute nonlinear term in the spectral kinetic energy equation magicsquirrel Main CFD Forum 4 December 13, 2011 17:45
DNS of turbulence in a channel flow YANGLIANG OpenFOAM 0 March 4, 2010 08:40
