execution problem
Old   May 15, 2012, 18:20
Question execution problem
Qingang Xiong
Qingang Xiong is on a distinguished road
Hi, Foamers,
I have modified a code and compile it with "wmake" but when I want to run it, it reports that the Command not found. So I go to my USER/platform/linux64GccDPOpt/bin/, and see that the execution is -rwxrwxrwx. I used chmod 755 to make it -rwxr-xr-x as standard Foam. But is still can not executable and said "Command not found". Has anyone ever encountered this problem before? Or know how solve this? Thank you.
Qingang Xiong is offline   Reply With Quote
Old   May 21, 2012, 06:48
alquimista is on a distinguished road
Has the default environmental variable $FOAM_USER_APPBIN (run 'echo $FOAM_USER_APPBIN') the value "~/OpenFOAM/user-X.x.x/platforms/....../bin" ???
alquimista is offline   Reply With Quote
Old   May 21, 2012, 09:56
Qingang Xiong
Dear alquimista,
Thank you very much for your reply! Fortunately It has been solved. But still thanks.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
UDF execution problem argeus Fluent UDF and Scheme Programming 4 April 15, 2011 14:04
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
