temperature gradient driven cavity flow.... OpenFOAM
Old   June 19, 2012, 09:23
Default temperature gradient driven cavity flow.... OpenFOAM
N Agrawal
Nishchal is on a distinguished road
I am relatively new to openFOAM.
I Want to setup a test case... temperature gradient driven cavity flow.
I am confused as to which solver to be used.
Is chtMultiRegionFoam a good choice to simulate this problem?
Also how to go about setting up this case? Are there any tutorials available?
I couldn't find any on my own. Any help would really be appreciated.
Nishchal is offline   Reply With Quote
Old   June 19, 2012, 09:33
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Use buoyantBoussinesqSimpleFoam and set boundary conditions accordingly.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   September 3, 2013, 06:13
Srivathsan N
Sherlock_1812 is on a distinguished road
Originally Posted by Nishchal View Post
Hi Nischal,
I am trying the same too. Have you been successful in implementing it? I know its an old thread but it shall be really helpful if you reply.
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   September 3, 2013, 08:36
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Originally Posted by Sherlock_1812 View Post
Hi Nischal,
it doesn't need to be implemented. It is already implemented in openFOAM.
All you have got to do is to use cavity mesh and set correct boundary conditions.
If you are not able to setup one, give me some more detailed information to help you setup your case.
Best,
Mojtaba
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   September 26, 2013, 13:35
Srivathsan N
I've modified the cavity case into a liquid bridge with free surfaces on top and the bottom and side walls. I want to observe buoyancy driven flow between the two free surfaces.
I'm having doubts with the bc's for p_rgh and U for this modified case. What should be the correct bc's in these conditions?
Thanks in advance!
Regards,
Srivaths
cavity flow, chtmultiregionfoam, openfoam 2.1
plz help:supersonic flow in shear driven cavity rajaero86 ANSYS 0 March 8, 2011 01:50
Wall correction for the temperature gradient Hagen OpenFOAM 0 March 7, 2011 20:04
Temperature Gradient at Wall sven OpenFOAM 7 November 1, 2010 17:25
temperature normal gradient on a boundary Sandrine Main CFD Forum 2 June 10, 2009 16:34
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 07:18
