Reading Velocity every timestep
Old   July 2, 2012, 07:22
Default icoUncoupledKinematicParcelFoam solver for particles - read U each time step?
skimmilk is on a distinguished road
So I'm new to using OpenFoam and C++, so pardon me if this is a very simple question. But so we've done some precomputation for the fluid fields, and they've been solved, and now I simply want to inject particles that will be affected by the said field. It's an uncoupled situation, and my mesh is dynamic (but that's already been solved, so that's not a big deal).
Anyways, so since it's uncoupled, I'm going with a lagrangian solver because I want the particle solution. Like I said, the fluid's been solved, and I can put together all the files using reconstructPar. So far, I've been able to leave out the particles and get the mesh to be read at each time step (I assume it's due to mesh.readUpdate() that I put in). I know it's fine because I can see the mesh moving the way I want in paraview. I cannot however, get U to update in the field each time. I'm basing my solver on icoUncoupledKinematicParcelFoam.
What I have tried is to put in a manual update each loop. I just copied and pasted the lines in the solver to recreate a new basicKinematicCollidingCloud each time. However, when I ran this, while the velocities looked right, my particles didn't move or age. I presume this is due to the cloud being recreated each time and the particles having to be reinjected into the new clouds at every step. I also tried changing the U into a non const field in the source code and then doing something like:
*(kinematicCloud.U()) = UatcurrentTimeStep
I think this is a good way to go, though I have been unsuccessful due to my lack of C++ experience.
Any help is appreciated! Thanks. OpenFoam 2.1.1
skimmilk is offline   Reply With Quote
Old   February 15, 2016, 03:56
Peter
potentialFoam is on a distinguished road
Dear Skimmilk,
hope your are still here at the forum ;-)
I am having the same problem, I would like to use
for an existing unsteady solution (gained by pimpleFoam).
Therefore, for every time step a case folder exists.
Applying
leads to two problems:
1.) a steady velocity field is used for the tracking of the particles
2.) I cannot set the time step for 'icoUncoupledKinematicParcelFoam' with the 'system/controlDict' file.
Has somebody more experience with 'icoUncoupledKinematicParcelFoam'?
potentialFoam is offline   Reply With Quote
Old   July 11, 2016, 07:26
Karelke Yu
cfdopenfoam is on a distinguished road
dear all.
has the problem solved?
cfdopenfoam is offline   Reply With Quote
Old   July 11, 2016, 07:59
Peter
Dear Karelke,
sorry, at least I did not solve it until now...
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Results of CFX Simulations Sof_70_Usthb CFX 3 July 9, 2011 06:15
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
maintaining a logarithmic velocity distribution Morten Andersen CFX 1 January 8, 2007 11:37
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 05:29
