merging meshes
Old   July 23, 2012, 07:10
Default merging meshes
amirr is on a distinguished road
Hi i have a situation where i have to combine 2 meshes tohether one rectangle into another ( one small volume into a bigger volume). mergeMesh works well but after running a simple flow i realize that the meshes are not combine at all. any suggestion ? thanks in advance
amirr is offline   Reply With Quote
Old   July 23, 2012, 09:18
Kalyan
kalyangoparaju is on a distinguished road
Amirr,
Make sure the meshes fit well. It might be a good idea to check the merged mesh in paraview after you merge them. There have been issues when other users saw a few gaps in the geometry.
The above process is assuming you setup your problem right
Kalyan
kalyangoparaju is offline   Reply With Quote
Old   July 23, 2012, 09:30
thanks for your reply Kalyan,
my meshes have different mesh resolutions, the mesh from the smaller volume has boundary patches. therefore stitchmesh doesnt apply in my case. when using merge mesh i have 2 superimpose meshes that is not one single mesh as I would like to have.
the question is how do i get only one mesh after mergemesh ? and how do I get rid of the internal patches from the smaller volume ?
Thanks
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Merging Hexa Meshes in ICEM screech1987 ANSYS Meshing & Geometry 11 March 13, 2014 11:45
[ICEM] Block/Hybrid strategy stuart23 ANSYS Meshing & Geometry 7 July 29, 2010 11:33
merging the meshes Virag CFX 2 March 5, 2007 06:41
Merging Meshes Matteo Giacobello. FLUENT 1 February 16, 2000 09:22
