Laplace, Grad, snGrad of T
Old   September 14, 2012, 04:52
Default Laplace, Grad, snGrad of T
Norbert Weber
dl6tud is on a distinguished road
I have a constant Temperature field with T=300:
internalField uniform 300;
boundaryField
floor
type fixedValue;
value uniform 300;
ceiling
type fixedValue;
value uniform 300;
fixedWalls
type fixedValue;
value uniform 300;
I try the following:
fvc::snGrad(T) = 0
fvc::grad(T) != 0
fvc::laplacian(constant,T) != 0
Having a constant Temperture field, I assume, that the gradient is zero. But in OF it is not zero!!! Using a vectorField (like U with Ux,Uy,Uz) the gradient is 0, that is ok.
The problem occurs when solving a temperature equation, where the laplacian is calculated. If the laplacian of a constant temperature field is not zero, I get wrong results.
Can anyone help?
dl6tud is offline   Reply With Quote
Old   September 17, 2012, 08:43
Norbert Weber
I tried different numerical schemes for grad and laplacian:
grad(T)
- Gauss linear: not correct
- leastSquares: ok
- fourth: ok
snGrad(T)
- corrected: ok
- uncorrected: ok
laplacian(x,T)
- Gauss xxxxxxx, uncorrected: not correct
It seems, there is a problem with Gaussian differencing schemes. When I use them on a constant field, I get grad/laplacian which is not zero.
Old   September 17, 2012, 09:13
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
are the grad/laplacian fields non-zero everywhere in your domain or only in certain places (skewed cells, boundary cells, …)?
Philip
bigphil is offline   Reply With Quote
Old   September 17, 2012, 10:00
Norbert Weber
Only in certain places:
grad(T)=
(2.77556e-14 0 2.77556e-14)
(-2.42861e-14 2.77556e-14 2.77556e-14)
(0 0 0)
(0 5.55112e-14 2.77556e-14)
(0 2.77556e-14 0)
(-2.94903e-14 0 -2.77556e-14)
(0 0 0)
(2.94903e-14 -2.77556e-14 0)
(-2.77556e-14 0 -2.77556e-14)
(0 -1.73472e-15 2.77556e-14)
(-6.93889e-15 -3.1225e-14 -2.77556e-14)
(1.73472e-15 -1.73472e-15 -2.77556e-14)
(0 0 0)
(0 -2.77556e-14 0)
Old   September 17, 2012, 10:13
bigphil's Avatar
Philip Cardiff
OK,
What are the certain places? Are they poor cells or boundary cells? It is very difficult to determine the problem without sufficient information.
The gradients you have given are very very small (less than 1e-13) and as such can be considered zero for most applications as you are approaching the machine tolerance.
Philip
Old   September 17, 2012, 10:34
Norbert Weber
Thanks for your answer, Philip!
It seems, that all cells have wrong values (see picture).
You are right, the values are very small, but unfortunately too high for the problem I am working on. These 'invented' temperatures induce a local fluid movement which destroyes my simulation.
Anyway the gradient of a constant temperature fields must be zero.
Old   September 17, 2012, 10:50
bigphil's Avatar
Philip Cardiff
Yes mathematically the gradient of a constant field is zero, however, numerical it may not be exactly zero due to the way the computer stores the number.
As a computer can only store to a certain precision for double precision floating point number, then you would expect that the gradient would be zero within this tolerance. I believe the non-zero numbers you are seeing are due to this tolerance.
If your simulations are sensitive to such very small numbers then you should consider using different base units (i.e. MPa instead of Pa, mm instead of m, etc.).
Philip
Old   September 18, 2012, 07:13
Norbert Weber
Thank you!
When using a 0-temperature field, gradient and laplace are zero, too. It is not perfect yet, but acceptable.
Why define a grad Scheme when using linearUpwind? Benedikt OpenFOAM Pre-Processing 2 August 10, 2019 08:19
gauss grad no correction for coupled boundary??!! doubtsincfd OpenFOAM 0 December 19, 2011 18:19
advanced function with snGrad Ingenierias2003 OpenFOAM 0 July 21, 2011 09:29
Grad evaluation cfdmarkus OpenFOAM Bugs 2 July 16, 2009 18:54
Stokes: Laplace vs. elasticity formulation (P1nc-P0) walli Main CFD Forum 0 May 4, 2009 09:42
