running in parallel error
Like Tree1Likes
  • 1 Post By saeid.oqaz
Old   September 27, 2012, 15:47
Default running in parallel error
saeid oqaz
saeid.oqaz is on a distinguished road
hi foamers.
i use pimpleDyMFoam and RBF Function. when running in parallel following error appear.
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: RBFMotionSolver
Radial Basis Function interpolation: Selecting RBF function: IMQB
Total points on moving boundaries: 0
Total points on static boundaries: 3925
Selected 0 control points on moving boundaries
Number of internal points: 34922
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading field rAU if present
Starting time loop
Courant Number mean: 0 max: 0 velocity magnitude: 0
deltaT = 0.012
Time = 0.012
Inverting RBF motion matrix
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Singular matrix
[0]
[0]     From function scalarSquareMatrix::LUdecompose(scalarSquareMatrix& matrix, labelList& rowIndices)
[0]     in file matrices/scalarMatrices/scalarSquareMatrix.C at line 94.
[0]
FOAM parallel run exiting
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] Singular matrix
[2]
[2]     From function scalarSquareMatrix::LUdecompose(scalarSquareMatrix& matrix, labelList& rowIndices)
[2]     in file matrices/scalarMatrices/scalarSquareMatrix.C at line 94.
[2]
[2]
mpirun has exited due to process rank 0 with PID 15707 on
node saeid-Inspiron-N4010 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
decomposeParDict :
numberOfSubdomains 3;
method          hierarchical;
simpleCoeffs
    n               ( 3 1 1 );
    delta           0.001;
hierarchicalCoeffs
    n               ( 3 1 1 );
    delta           0.001;
    order           xyz;
metisCoeffs
    processorWeights ( 1 1 1 1 );
manualCoeffs
    dataFile        "";
distributed     no;
roots           ( );
thanks for helping me.
sunshuai likes this.
saeid.oqaz is offline   Reply With Quote
Old   September 27, 2012, 19:52
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Your velocity is 0. May be this is causing the problem?
Or may there is some problem with solver you are using in the fvSolution dictionary.
owayz is offline   Reply With Quote
Old   September 28, 2012, 12:56
saeid oqaz
thanks Awais .
i change solver in fvsolution dictionary and work fine. thanks again.
Old   July 8, 2013, 23:33
sunshuai
sunshuai is on a distinguished road
Originally Posted by saeid.oqaz View Post
thanks Awais .
I have a same problem.I want to know how to change solver in fvsolution dictionary? Thanks
sunshuai is offline   Reply With Quote
Old   July 25, 2013, 06:52
benarab
didamiamia is on a distinguished road
hi,
have you found what to change in fvSolution to resolve the probleme of Singular matrix?
thanks for your answer.
didamiamia is offline   Reply With Quote
Old   July 25, 2013, 12:28
sunshuai
Originally Posted by didamiamia View Post
hi,
sorry,I can't solve this problems ,and this puzzled me.
Old   June 5, 2017, 11:29
Collin Strassburger
Collin is on a distinguished road
For anyone who happens to end up here seeking answers:
The singular matrix issue is caused by there not being any control points within the processor domain. I.e. if you have a decomposed grid then one (or more) of your processor domains do not interact directly with the moving patch. This can be resolved by changing decomposition schemes or modifying domain sizes (however, there are a great many instances where such things are not readily feasible).
Collin is offline   Reply With Quote
Problem running perturbUCyl sen.1986 OpenFOAM 17 June 4, 2019 05:56
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
