Trouble creating an injection pulse (interFoam)
Old   September 28, 2012, 22:03
Default Trouble creating an injection pulse (interFoam)
smschnob is on a distinguished road
Greetings,
I am very new to OF. I've been using it for only a couple weeks now, and I'm runnning into some issues. I went through the interFoam/les/nozzleFlow2D tutorial (using OpenFOAM v2.1) and would like to make some changes to it. In the tutorial liquid is ejected from the nozzle through the entire simulation. I would like to change the model so only a short pulse of liquid is ejected from the nozzle. Basically, I would like to specify an injection duration. Does anyone have any thoughts on how I can accomplish this? I should also mention that I made one change to the tutorial. I wanted to specify the inlet using total pressure instead of velocity. Listed below is the code.
In 0/p_rgh ...
inlet
type totalPressure;
p0 1e6;
U U;
rho none;
phi phi;
psi none;
gamma 1;
value uniform 1e6
In 0/U ...
inlet
type pressureInletVelocity;
value uniform (0 0 0);
In addition, I tried to add a table to create the pulse of liquid but that didn't seem to work. Listed below is the code I used.
inlet
type uniformTotalPressure;
pressure table
(0 1e6)
(5e-6 0)
p0 1e6;
U U;
rho none;
phi phi;
psi none;
gamma 1;
value uniform 1e6
Thank you!
smschnob is offline   Reply With Quote
Old   October 10, 2012, 05:52
Michiel
michielm is on a distinguished road
You could use something like this:
inlet
        type            uniformFixedValue;
        uniformValue    table
                (0      (0.05 0 0))
                (0.05   (0.05 0 0))
                (0.1    (0 0 0))
That will give you an x-velocity of 0.05 m/s from t=0 to t=0.05 which then decreases linearly to 0 from t=0.05 to t=0.1
michielm is offline   Reply With Quote
Old   October 10, 2012, 12:26
inlet
        uniformValue    table
                (0      (0.05 0 0))
                (0.05   (0.05 0 0))
                (0.1    (0 0 0))
Thank you so much! That's exactly what I was looking for.
Thanks again,
Scott
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC mgdenno OpenFOAM Community Contributions 4 July 1, 2012 08:16
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
[blockMesh] Trouble with blockMesh kupiainen OpenFOAM Meshing & Mesh Conversion 40 January 10, 2009 17:44
error when creating an injection matt FLUENT 0 July 9, 2007 17:18
