How to run potentialFoam and simpleFoam together .
Like Tree7Likes
  • 1 Post By openfoam_user
  • 2 Post By petros
  • 1 Post By MathiasSonderskov
  • 3 Post By petros
Old   October 1, 2012, 06:24
Default How to run potentialFoam and simpleFoam together .
sandip
vmsandip2011 is on a distinguished road
I want to run the potentialFoam with few iterations and then run the simpleFoam using the same controlDict and fvSolution files , what changes are needed for openFoam2.1.0
Is it necessay to specify the residual controls in fvSolution file for simpleFoam?
Idea is to use results of potentialFoam for simpleFoam as initial conditions.
with regards.
vmsandip2011 is offline   Reply With Quote
Old   October 2, 2012, 09:07
stephane sanchi
openfoam_user is on a distinguished road
have a look at the motorbike tutorial. Exactly what you want (potentialFoam and then simpleFoam).
~/OpenFOAM/OpenFOAM-2.1.x/tutorials/incompressible/simpleFoam/motorBike
Regards,
Stephane.
hogsonik likes this.
openfoam_user is offline   Reply With Quote
Old   June 8, 2015, 13:45
Domi
macRC is on a distinguished road
Dear Foamers,
I exactly wanted to do the same, first initializing with potentialfoam and then running the simulation with simplefoam.
I compared the residuals and results with AND without initialization, BUT there is no difference at all. What could be wrong?
My workflow is to create a single mesh, after that decomposepar it, run potentialfoam parallel, run simplefoam in parallel and reconstruct it again in the end.
thanks a lot
macRC is offline   Reply With Quote
Old   June 9, 2015, 05:27
Sune Niemann
Sune is on a distinguished road
Is this what you want?
Initialization with potentialFoam
Sune is offline   Reply With Quote
Old   June 11, 2020, 14:53
Mathias Sønderskov Schaltz
MathiasSonderskov is on a distinguished road
Originally Posted by macRC View Post
Dear Foamers,
thanks a lot
What's the advantage of initializing with potentialFoam before simpleFoam?
MathiasSonderskov is offline   Reply With Quote
Old   June 11, 2020, 15:17
Petros Ampatzidis
petros is on a distinguished road
potentialFoam solves only for the velocity potential.
There are times when you are not entirely sure about the initial conditions of your problem. Running potentialFoam prior to more advanced solvers can help you initialise your simulation with "better" initial conditions, which can reduce the computational cost.
Petros
hogsonik and allanZHONG like this.
petros is offline   Reply With Quote
Old   June 11, 2020, 15:53
Petros
Thanks very much.
So you would have a controldict saying let's say 200 iterations for potentialfoam before running 2000 in simpleFoam.
Would one have to save them as controlDict.potentialFoam and controlDict.simpleFoam then or what's best practice?
And in a bat script you'll just run one solver after the other, correct?
granzer likes this.
Old   June 12, 2020, 05:58
Petros Ampatzidis
As far as I am concerned, you don't have to set up different controlDicts. You just need to modify your fvSolution file to include something like:
potentialFlow
    nNonOrthogonalCorrectors 3;
For a complete set up, please have a look at the windAroundBuildings tutorial case.
https://github.com/OpenFOAM/OpenFOAM...roundBuildings
Old   April 2, 2021, 10:23
Mandeep Shetty
granzer is on a distinguished road
potentialFlow
Does this mean that potentialFoam solver will run for 3 iterations and then simpleFoam will take over for the number of iterations mentioned in controlDict?
granzer is offline   Reply With Quote
Old   April 2, 2021, 10:38
Petros Ampatzidis
That's correct.
Old   April 2, 2021, 10:46
Mandeep Shetty
That's correct.
Thank you @petros. But here it says potentialFoam runs just one iteration with n (here n=3) corrector loops. potentialFoam not writing and only one iteration
Old   April 2, 2021, 10:56
Petros Ampatzidis
Yes but non-orthogonal corrector loops are also iterations. potentialFoam does not contain any time loop - it just iterates over the user-specified non-orthogonal velocity potential corrector loops.
granzer, Muerio and allanZHONG like this.
Initialization with potentialFoam Sune OpenFOAM Running, Solving & CFD 6 March 2, 2016 12:18
simpleFoam airfoil2d Continuity error cannot be removed junkie71189 OpenFOAM Running, Solving & CFD 3 August 9, 2012 13:58
BC for simpleFoam from potentialFoam results Geon-Hong OpenFOAM Running, Solving & CFD 0 April 5, 2011 22:23
Problem with skew faces in simpleFoam... HelloWorld OpenFOAM 7 May 14, 2010 11:28
Getting faster convergence in simpleFoam basneb OpenFOAM 8 February 9, 2010 04:20
