write forward, reverse reaction coefficient, reaction rate in ChemFoam
Old   October 15, 2012, 09:07
Default write forward, reverse reaction coefficient, reaction rate in ChemFoam
Terrence Nguyen
hismother is on a distinguished road
Hi Foamers,
I am using ChemFoam to check whether my chemical mechanism is good. Now I want to print out the forward, reverse reaction coefficient (kf, kr) as well as forward, reverse reaction rate for each reaction from my reaction mechanism for every chemical timestep. After that I can plot the kf, kr over the time. From the code I know it kf, kr are calculated in ODEChemistryModel.C in each iteration during calculating omega but I can't manage to print them out and save in a output file. If anyone has any idea about it, would be great to enlight me.
Terrence.
hismother is offline   Reply With Quote
Old   November 6, 2012, 01:48
Hanzo is on a distinguished road
Hi Terrence,
I'm also digging in the source code of chemFoam & friends to solve my problem
(http://www.cfd-online.com/Forums/ope...-solution.html)
and I wonder if you have managed to print out the reaction coefficients and rates.
Hanzo is offline   Reply With Quote
Old   November 6, 2012, 03:53
Terrence Nguyen
just go to ODEchemistrysolver.C. There you can find the place where kf, kr as well as reaction rates are computed. Just use Info command to print them out and they will be printed out in your log file.
Old   November 7, 2012, 03:33
thanks for the info.
Actually, I tried to avoid editing ODEchemistryModel.C (I guess you were reffering to this file, right?) because I wanted to avoid defining my own lib and include this in chemFoam. Since there is no other option to get these values, I gave up and recompiled it into a mychemistryModel library.
Took some time but now it's fine.
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh elvis OpenFOAM Community Contributions 210 January 30, 2017 18:57
Reaction rate under multi phases kongl1986 Fluent UDF and Scheme Programming 3 September 7, 2012 08:43
Who can write the binary diffusion coefficient ?? Hsin-Ping FLUENT 1 April 15, 2002 02:22
reaction rate as UDF variable sivakumar FLUENT 4 February 12, 2002 00:31
