Odd error when using OpenFOAM compiled with --march=native
Old   October 15, 2012, 23:36
Default Odd error when using OpenFOAM compiled with --march=native
Nishit Joseph
JLight is on a distinguished road
Hi OF Users!
I recentely compiled the OpenFOAM-2.1.x on two types of processor.
Machine 1
Dell Laptop: Intel i7-2670QM CPU
Machine 2
HPC Cluster: AMD Opteron Processor 2376
Everything seemed fine until I tried the following.
1. Run a case using rhoCentralFoam on Machine 2
2. Download the case to Machine 1
3. Try to continue the run on Machine 1.
I get this error.
--> FOAM FATAL ERROR:
Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListINS_6VectorIdEEEEEE
    From function dynamicCast<To>(From&)
    in file /home/jlight/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/typeInfo.H at line 93.
FOAM aborting
Both were compiled with gcc 4.7.2. Is the error possible because of the compiler option? Or should I start considering re-compiling the OF without the -march=native option.
I used older version of OF (1.7.1 and 2.0.0) without the march=native option and never had this issue.
Cheers!
Nishit
JLight is offline   Reply With Quote
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 03:14
OpenFOAM compiled with Intel C++ Compiler? af631717 OpenFOAM Running, Solving & CFD 4 June 5, 2009 06:41
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 18:06
