Foam:: Error:: PrintStack
Old   October 18, 2012, 18:03
Smile Foam:: Error:: PrintStack
Reno
jr33 is on a distinguished road
I am running an example of flow in pipe using openfoam (Ubuntu), I get following error, although it works fine till time point 16, How to fix the error.
Files are here:
http://dl.dropbox.com/u/68983831/files.zip
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 15
Courant Number mean: 2.30651e+31 max: 4.76733e+34
DILUPBiCG: Solving for Ux, Initial residual = 0.998836, Final residual = 0.0837974, No Iterations 14
DILUPBiCG: Solving for Uy, Initial residual = 0.999846, Final residual = 0.079946, No Iterations 5
DILUPBiCG: Solving for Uz, Initial residual = 0.999593, Final residual = 0.0819008, No Iterations 13
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.000810451, No Iterations 2
time step continuity errors : sum local = 8.6096e+60, global = -1.31187e+44, cumulative = -1.31187e+44
DICPCG: Solving for p, Initial residual = 0.997834, Final residual = 0.00011985, No Iterations 1
time step continuity errors : sum local = 3.07997e+62, global = 9.1217e+45, cumulative = 8.99052e+45
ExecutionTime = 1.84 s ClockTime = 3 s
Time = 16
Courant Number mean: 3.06096e+62 max: 5.97395e+65
DILUPBiCG: Solving for Ux, Initial residual = 0.585237, Final residual = 0.0331803, No Iterations 23
DILUPBiCG: Solving for Uy, Initial residual = 0.58276, Final residual = 0.0407138, No Iterations 12
DILUPBiCG: Solving for Uz, Initial residual = 0.908282, Final residual = 0.0424477, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam:ICPreconditioner::calcReciprocalD(Foam::Field <double>&, Foam::lduMatrix const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 Foam:ICPreconditioner:ICPreconditioner(Foam::lduMa trix::solver const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#5 Foam::lduMatrix:reconditioner::addsymMatrixConstru ctorToTable<Foam:ICPreconditioner>::New(Foam::lduM atrix::solver const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#6 Foam::lduMatrix:reconditioner::New(Foam::lduMatrix ::solver const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#8 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/icoFoam"
#10 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#11
Floating point exception (core dumped)
jr33 is offline   Reply With Quote
Old   October 18, 2012, 18:19
Assistant Moderator
Bernhard Gschaider
No it doesn't. Have a look at time 15: Courant numbers of the order 1e34 are not fine in this universe
Problems start probably even further up (there is probably a problem with your case)
Files are here
Best way to find the error is write out every time-step (with 16 timesteps to failure this should be possible), have a look at them and find out what is going wrong
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 18, 2012, 18:23
Reno
I saw at time point 1:
Courant Number mean: 5.80776 max: 1368.61
Thanks
Old   October 18, 2012, 18:29
Default Above error came when I fixed keyword laplacian
Reno
Create time
Create mesh for time = 10
Reading field p
Reading field U
Starting time loop
Time = 11
Courant Number mean: 1.54422e+12 max: 7.57587e+14
--> FOAM FATAL IO ERROR:
keyword laplacian(nu,U) is undefined in dictionary "/home/jay/OpenFOAM/jay-2.1.1/run/tutorials/incompressible/simpleFoam/elbow/system/fvSchemes::laplacianSchemes"
file: /home/jay/OpenFOAM/jay-2.1.1/run/tutorials/incompressible/simpleFoam/elbow/system/fvSchemes::laplacianSchemes from line 44 to line 50.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 400.
FOAM exiting
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
