What means "bounding epsilon"?
Like Tree1Likes
  • 1 Post By gonpe
Old   October 25, 2012, 05:15
Default What means "bounding epsilon"?
Mattia
gara1988 is on a distinguished road
Hello, I have an easy question. I don't understand what means "bounding epsilon" or k, during running of simpleFoam. Is there someone that can tell me what it means?
Thanks a lot.
Best Regards.
Mattia
gara1988 is offline   Reply With Quote
Old   October 25, 2012, 09:51
Simone
batta31 is on a distinguished road
Hi Mattia,
I have experienced the same problems. What I can suggest you is to evaluate carefully the initial/boundary values for your turbulent variables, and maybe you could have a look to your fvSchemes and fvSolution files.
More precisely:
- in fvSchemes you could use upwind scheme for the terms involving your turbulent variables;
- in fvSolution have a look to the tolerances you use for your turbulent variables and to the relaxation factors (maybe you could be a little more conservative and use a lower value of relaxation factor)
With these modifications my simulation has not diverged any more.
Best regards
Simone
batta31 is offline   Reply With Quote
Old   October 26, 2012, 08:10
Default Bounding Turbulence variables
Goncalo Pedro
gonpe is on a distinguished road
Hi Mattia
The solver is reporting high or low values of a turbulence variable. It is typically indicative of some instability within the solution.
As the post above mentions there are a couple of ways to deal with it. In my experience it often comes down to mesh quality. Maybe lack of refinement in certain areas with high gradients etc.
Sometimes these bounded values go away as the solution converges.
Goncalo
batta31 likes this.
gonpe is offline   Reply With Quote
Old   October 29, 2012, 08:59
Mattia
Thanks batta31 and gonpe for the replies.
Best regards.
error means? hanid Main CFD Forum 0 September 8, 2008 13:25
BC evaluation by means of external lists allocated in the solver shrina OpenFOAM Running, Solving & CFD 2 January 18, 2007 11:29
What does the floating point error means? jon william FLUENT 1 October 8, 2006 08:57
plot order points... what does it means ? Cyril FLUENT 0 June 7, 2006 05:56
What means % in Fortran? What means % in Fortran Main CFD Forum 2 April 20, 2004 14:34
