November 21, 2012, 15:44 |
Mesh skewness correction
Jakub Pola
Rep Power: 15 |
Dear Foamers,
I have a question related to fvSchemes and interpolation schemes. I have read that mesh skewness affecs interpolation calculation. Is there a discretisation scheme which may help correcting this issue. I'm curious about skewLinear (Linear with skewness correction) from Numerical schemes. Does it somehow help with the calculations on skewed mesh? Does skewCorrected is the same scheme in OF 2.1.1? How to use it? Because wehn I want to put it in fvSchemes Code:
interpolationSchemes { default skewCorrected; } Thank you in advance for your help. Jakub. |
October 23, 2013, 14:07 |
Malik
Rep Power: 13 |
I have almost the same issue : how to use the skewness correction in OpenFOAM. To me the skewness is critical especially when we do an interpolation. Hence it has to be mentionned in the interpolation schemes. Plus, it may be used in the div schemes of non surfaceField like U : when we integrate over a cell, we will need to interpolate the field from the center to the surface. I guess for a surfaceField, it is useless. If then we use : Code:
interpolationSchemes { default linear skewCorrected; } divSchemes { div(U) Gauss linear skewCorrected; } Code:
interpolationSchemes { default linear; } divSchemes { div(U) Gauss linear; } Then I think I don't really understand how this skewness correction work... |
October 23, 2013, 14:29 |
Jakub Pola
Rep Power: 15 |
Hey,
Neither do I understand. It would be great to hear little bit about that. Does anyone have some article. Jakub. |
October 24, 2013, 09:47 |
joegi
Rep Power: 16 |
Let me put my two cents. Mesh skeness will reduce the order of face integration. Basically it is the deviation from the face center to the actual face integration point (the intersection between the vector joining two neighboring CV and the common face), and this is already taken care of in OF. You can refer to Hrvoje Jasak phd thesis. If you have highly skewed cells you can use least squares for gradients calculation in order to reduce the numerical diffusion. Maybe increasing the number of corrector steps will help as well. jg |
November 27, 2013, 10:09 |
#5 | |
Philipp
Rep Power: 26 |
Edit: Ok, so after some more reading and searching I found the following: Mesh weights (also used for central differencing in OF) for the cell-to-face interpolation are calculated using this formula: http://openfoamwiki.net/index.php/Op...on_%28class%29 In the source code one can find the calculation in the "surfaceInterpolation.C" file, function is called "makeWeights()". Now, obviously this is not just the standard linear weighting, as it is not only the distance of cell centers to the cell face that counts, but also the projection of the vectors on the face normal. But also in the thesis I can not find any derivation of that fomula, I just found some words about the diffusion correction. Unfortunately, I could not adapt the lines to the convective / face value calculation.
The skeleton ran out of shampoo in the shower. Last edited by RodriguezFatz; November 28, 2013 at 07:26. |
November 9, 2018, 06:45 |
Declaration of skewCorrected schemes
Viktor Klüber
Rep Power: 8 |
Moukalled'16 gives an extensive report on discretization schemes of convective, diffusive, source terms etc, and briefly describes how they are implemented in OpenFOAM. Concerning a skew corrected gradient scheme he indicates the definition as Code:
gradSchemes { default Gauss skewCorrected linear; } I worked on an unstructured skew mesh like shown in the picture Basic-geometry-of-the-pipeline-and-polyhedral-mesh-generated-on-the-pipe.png.jpeg By using skew correction I was able to reduce truncation errors essentially. In case you are working on unstructured meshes, I want to draw your attention on this thread. It is a discussion about the consistency of green-gauß and least-square gradient discretization schemes. Regards, Viktor Last edited by ViktorKL; November 9, 2018 at 11:15. |
correction, discretisation, fvshemes, skewness |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 18:47 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
