August 24, 2016, 03:48 |
#21 |
yagmur
Rep Power: 14 |
Dear User,
I also tried to reduce parcelspersecond in my case, it didnt work. The mass introduced is very less than the amount that must be injected . I use Rommler Distribution dmin 3e-5 dmax 4e-5 d 3.5e-5 n=3. I am not sure if I represent well all droplet size? Thanks in advance, |
July 4, 2017, 03:04 |
incorrect introduced mass in sprayFoam (OF 4.1)
#22 |
Sadegh Ebadi
Rep Power: 11 |
Hello everybody,
I also have the same problem with the introduced mass, it is lower than what I had defined! I'm using OF 4.1 (latest version of OpenFoam), I thought that the problem sushant had mentioned should have been solved by now! But I see it's just working for aachen bomb tutorial! I know that there should be a harmony between totalmass, massprofile, and ParcelsPerSecond parameters but some how I am confused by the way they relate to each other. I have attached my sprayCloudProperties file. I would appreciate any idea to solve this problem. |
July 5, 2017, 02:43 |
#23 |
Golden
Rep Power: 8 |
Hello everyone,
I am doing a combustion things smallpoolfire, I added the chemkin folder and also given the path of chemkin file and transport properties in thermophysical properties. But it showing following error: From function static typename Table::iterator Foam::basicThermo::lookupTherm o(const Foam::dictionary&, Table*) [with Thermo = Foam:siReactionThermo; Table = Foam::HashTable<Foam::autoPtr<Foam:siReactionThe rmo> (*)(const Foam::fvMesh &, const Foam::word&), Foam::word, Foam::string::hash>; typename Table::iterator = Foam::HashTable<Foam::autoPtr<Foam:siReactionThe rmo> (*)(const Foam::fvMesh &, const Foam::word&), Foam::word, Foam::string::hash>::iterator] in file /home/buzz2/pawan/OpenFOAM/OpenFOAM-v1612+/src/thermophysicalModels/ basic/lnInclude/basicThermoTemplates.C at line 73. |
April 4, 2018, 15:31 |
#24 |
Sadegh Ebadi
Rep Power: 11 |
Greetings to all,
As a response to this post I have tried many parameters in order to find their effect on the injected mass. For example I tried changing number of parcels but nothing special had changed in the mass injected. After all I have tried my case with different geometries: A full cylinder and a 30 degree sector of that cylinder. I figured out that in the case of full cylinder the injected mass at the end of simulation is the same as the mass specified in spraycloudProperties. And the mass in the case of 30 degree sector of the cylinder is proportional to the mass of full cylinder. Clearly, in the spraycloudProperties we specify the full geometry mass (here, full cyilinder) and when our geometry is 30 degree sector, the injected mass is 30/360=1/12 of the specified mass. If we specify the mass 6.0 mg in the case of full cylinder we get this 6.0 mg as injected mass, but in the case of 30 degree sector of the cylinder we get 6.0/12=0.5mg at the end of the simulation. Good Luck |
July 10, 2020, 00:38 |
#25 | |
Riddhideep Biswas
Rep Power: 6 |
Thanks a lot. Your suggestion is really helpful. Does all the parcels injected throughout the simulation has the same mass? Or only parcels injected at a particular time step has same mass and parcels at different time steps can have different mass? |
July 10, 2020, 00:39 |
#26 | |
Riddhideep Biswas
Rep Power: 6 |
Thanks a lot. Your suggestion is really helpful. I still have a question. Does all the parcels injected throughout the simulation has the same mass? Or only parcels injected at a particular time step has same mass and parcels at different time steps can have different mass? |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
sprayFoam crashes | lukasfischer | OpenFOAM Running, Solving & CFD | 3 | July 14, 2013 11:08 |
