Solving 2D Heat Transfer Problem
Old   December 24, 2012, 10:35
Default Solving 2D Heat Transfer Problem
SebastianG is on a distinguished road
Hello guys,
I am new to openFoam and have some flow problems. Now I would like to solve 2D heat transfer problem with two different solid materials (no flow just conduction). Therefore I have chosen the scalarTransportFoam solver, which solves dT/dt + grad(U*T) + laplace(DT*T) = 0 . Due to the fact that I consider solid materials my U-field is set to zero in the boundary and initial conditions.
I would like to know how I can vary my diffusion coefficient/ heat conductivity DT in the field?
Therefore I have created a mesh with gmsh that consists of two sets. When running gmshToFoam in the folder constant/polyMesh/sets two files "Pipe" and "Filling" are created.
How can specify the value of DT for the two sets in the transportProperties file?
Or am I on the path for such a problem?
Kind regards and merry Chrismas!
Sebastian
SebastianG is offline   Reply With Quote
Old   December 30, 2012, 07:19
akidess's Avatar
Anton Kidess
http://www.cfd-online.com/Forums/ope...materials.html
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 02:09
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
