December 30, 2012, 11:22 |
stop in parallel run.what can be the cause?
Ehsan
Rep Power: 26 |
could someone help with this error?
thanks. Code:
Time = 0.001448178 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 2.17729e-07, Final residual = 4.16691e-17, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 2.16012e-07, Final residual = 3.85315e-17, No Iterations 3 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 3.74091e-08, Final residual = 4.16705e-15, No Iterations 3 ExecutionTime = 2917.58 s ClockTime = 2939 s Mean and max Courant Numbers = 0.00841303 0.0499964 deltaT = 3.74883e-09 Time = 0.001448182 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 2.17778e-07, Final residual = 4.89662e-17, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 2.15995e-07, Final residual = 3.71119e-17, No Iterations 3 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 3.75337e-08, Final residual = 4.18908e-15, No Iterations 3 ExecutionTime = 2917.6 s ClockTime = 2939 s Mean and max Courant Numbers = 0.00841311 0.0499973 deltaT = 3.74883e-09 Time = 0.001448186 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 2.17833e-07, Final residual = 4.57998e-17, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 2.15984e-07, Final residual = 3.97908e-17, No Iterations 3 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 3.76702e-08, Final residual = 4.13611e-15, No Iterations 3 [0] [0] [0] --> FOAM FATAL ERROR: [0] Maximum number of iterations exceeded [0] [0] From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const [0] in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69. [0] FOAM parallel run aborting [0] [0] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #1 Foam::error::abort() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #2 Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::T(double, double, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" [0] #3 Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" [0] #4 Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::correct() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" [0] #5 [0] in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoCentralFoam" [0] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #7 [0] in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoCentralFoam" -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 1873 on node thesis-X58A-UD7 exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- Killing PID 1869 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 1869 was already dead thesis@thesis-X58A-UD7:~/Desktop/method_4_2_2(revised)-laminar.042$ paraFoam created temporary 'method_4_2_2(revised)-laminar.042.OpenFOAM' /opt/openfoam210/bin/paraFoam: 1: Syntax error: "(" unexpected thesis@thesis-X58A-UD7:~/Desktop/method_4_2_2(revised)-laminar.042$ |
OF 2.0.1 parallel running problems | moser_r | OpenFOAM Running, Solving & CFD | 9 | July 27, 2022 03:15 |
stop when I run in parallel | Nolwenn | OpenFOAM | 36 | March 21, 2021 04:56 |
compiling firefoam | Farshad_Noravesh | OpenFOAM | 27 | December 24, 2012 04:21 |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
