what do global and cumulative terms in continuity refer to exactly?
Like Tree5Likes
  • 2 Post By immortality
  • 3 Post By fumiya
Old   January 12, 2013, 03:55
Default what do global and cumulative terms in continuity refer to exactly?
immortality's Avatar
Ehsan
immortality is on a distinguished road
at results there are 3 types of residuals of continuity equation.whats the definition of them and difference?if cumulative and or global be negative whats wrong in the problem?
kcavatar and vivek05 like this.
immortality is offline   Reply With Quote
Old   January 13, 2013, 05:17
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
For the solvers of incompressible fluid, take a look at the
src/finiteVolume/cfdTools/incompressible/continuityErrs.H:
    volScalarField contErr(fvc::div(phi));
    scalar sumLocalContErr = runTime.deltaTValue()*
        mag(contErr)().weightedAverage(mesh.V()).value();
    scalar globalContErr = runTime.deltaTValue()*
        contErr.weightedAverage(mesh.V()).value();
    cumulativeContErr += globalContErr;
    Info<< "time step continuity errors : sum local = " << sumLocalContErr
        << ", global = " << globalContErr
        << ", cumulative = " << cumulativeContErr
        << endl;
From the above definitions, the difference between the local and global
continuity error is whether the magnitude of divergence is taken or not.
The "local" error is a measure of the continuity of each cell and the
"global" error represents the continuity in the whole computational domain.
If the global error converges to zero, I think the negative value is of no matter.
I have no idea about the importance of considering the cumulative error.
Fumiya
kiddmax, vbnhfylbh and kcavatar like this.
fumiya is offline   Reply With Quote
Old   January 16, 2013, 09:15
Ehsan
thanks fumiya
I cant grasp how the total continuity is calculated.my case is compressible.
What does mean cumulative continuity error?
Any hint is accepted here!
Old   September 6, 2018, 03:05
krishna kant
kk415 is on a distinguished road
hey fumiya,
I am also not able to understand what is the meaning of these errors, if sumLocalcontErr is the continuity error for a cell then for what cell it is giving the value. I mean it should give value for all cell. Is it the maximum that is calculated too?
kk415 is offline   Reply With Quote
Old   September 6, 2018, 05:06
Question
krishna kant
I am interpolating the velocity field from coarser mesh to finer mesh and then checking the continuity error, this gives me SumLocalErr a relatively high value (inc. from 1e-9 to 1e-4) but globalErr remains of same (i.e. 1e-19 to 1e-20). What this implies? Is the interpolation wrong? Can this effect my solution?
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
