Initial U Field
Old   January 18, 2013, 10:35
Default Initial U Field
Mattia
gara1988 is on a distinguished road
Hello, I have to use a solver than can receive a pre-solved field. How can I impose this field? Must I copy the folder of pre-solved field?
Best regards.
Mattia
gara1988 is offline   Reply With Quote
Old   January 18, 2013, 10:57
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
If you use the same mesh for both solvers, what you need to do is
to copy the folder of pre-solved field and read the field in the second
solver.
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
