RhoCentralFoam-MultiSpecies-NonReacting
Like Tree2Likes
  • 1 Post By Marpole
  • 1 Post By Marpole
Old   January 23, 2013, 18:25
Default RhoCentralFoam-MultiSpecies-NonReacting
Jack Lee
Azanulbizar is on a distinguished road
I need to adapt rhocentralFoam to do mulitspecies non reacting simulation. Basically, at the inlet, I would like to inject 2-3 types of gases.
Can anyone gives me a suggestion of how to go about this matter?
The rhoCentralFoam.C looks much more complicated compared to other solvers and hence, I dont have much clue to change the codes so that I can take in multispecies/gases I need to inject in.
Thank you very much.
Azanulbizar is offline   Reply With Quote
Old   March 8, 2015, 03:53
apurva
apu111 is on a distinguished road
Hi Azanulbizar,
Have you solved this problem?
So is it possible to introduce 2-3 non-reacting gases mixture in rhoCentralFoam?
I am working on delaval nozzle and I want to introduce them at nozzle inlet.
Thanks in advance!
apu111 is offline   Reply With Quote
Old   March 9, 2015, 12:49
Mattia de\' Michieli Vitturi
demichie is on a distinguished road
I have published a couple of years ago a paper on a new OpenFOAM solver we have developed for a two-phase model using a central scheme approach similar to that used in rhoCetralFoam:
La Spina, G. & de' Michieli Vitturi, M. High-Resolution Finite Volume Central Schemes for a Compressible Two-Phase Model SIAM Journal on Scientific Computing, SIAM, 2012, 34, 861-880
In a more recent work we have also introduced mass transfer in the model.
If you are interested you can send an email to the first author asking for the code.
Ciao
Mattia
P.S. I have attached a figure from one of the papers comparing the results of a simulation with those of a lab experiments for the interaction of a shock wave with a cylindrical bubble.
demichie is offline   Reply With Quote
Old   March 31, 2016, 14:46
apurva
Thanks demichie for your reply. I have gone through the paper but it's for 2 phase flow. How do I edit rhoCentralFoam.C to simlulate multi-species in the gaseous phase? Thanks in advance!
Old   December 8, 2017, 11:19
Reza khodadadi
reza_65 is on a distinguished road
Send a message via ICQ to reza_65 Send a message via AIM to reza_65 Send a message via Yahoo to reza_65
Originally Posted by demichie View Post
Ciao
Mattia
It is a very nice job, well done. In 2010 I developed a two-phase flow solver, by using interFoam, for simulating shock bubble interactions as well. Also, I published an article about shock capturing which shows rhoCentralFoam has got the best shock capturing capability in openFoam solvers.
https://www.researchgate.net/publica...ds_in_OpenFOAM
DOI: 10.2298/TSCI130425048K
Best Regards,
Reza
reza_65 is offline   Reply With Quote
Old   August 27, 2020, 10:10
saturn_K is on a distinguished road
Hi Azanulbizar
Could you finally find your answer? because I have exactly the same problem with rhoCentralFoam solver and I would be really grateful if you can help me how can I handle it.
Regards,
Keivan
saturn_K is offline   Reply With Quote
Old   August 27, 2020, 12:57
Domenico Lahaye
dlahaye is on a distinguished road
Use reactingFoam with combustion de-activated?
dlahaye is offline   Reply With Quote
Old   August 28, 2020, 10:49
Hi dlahaye
Thank you for your suggestion. But as far as I know, reactingFoam solver doesn't have the ability to capture the discontinuities like shock waves.
Regards,
Keivan
Old   August 28, 2020, 11:03
clapointe is on a distinguished road
There are various flavors of reacting rhoCentralFoam floating around (e.g. reactingPimpleCentralFoam, hy2Foam). I've put one together based on similar threads for older versions of openfoam... it can be found in this repo : https://github.com/duncanam/rhoReactingCentralFoam.
Caelan
clapointe is offline   Reply With Quote
Old   August 30, 2020, 11:38
Domenico Lahaye
Originally Posted by saturn_K View Post
Hi dlahaye
Regards,
Keivan
Thank you for elaborating your question.
Old   September 2, 2020, 21:17
Caelan
Dear Clapointe
Thank you for your great help. Actually, I tried to use your solver and I encountered many issues and fortunately, I could solve all except one. I need to use a non-ideal equation of state (e.g. Peng-Robinson), but all the thermo types in your solver are based on perfectGas EOS. Do you know how I can add a new thermo type to your solver?
Best Regards,
Keivan
Old   September 2, 2020, 23:41
It is simply an extension of rhoCentralFoam, so it uses existing openfoam thermo libraries. You'll need to add anything that doesn't exist natively.
Caelan
Old   September 17, 2020, 05:56
Caelan
Dear Clapointe
Still, I am trying to use your solver and so far I have had good progression and I should thank you for that.
But recently, I got a new error which is related to the "fixedFluxPressure" boundary condition.
[3] --> FOAM FATAL ERROR:
[3] updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient.
[3]
[3] From function virtual void Foam::fixedFluxPressureFvPatchScalarField::updateC oeffs()
[3] in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 157.
[3]
This happens after the first iteration. Have you ever encounter this error? Do you know how I can fix it?
Regards,
Keivan
Old   September 17, 2020, 10:48
In short, you'll notice that no tutorials for rhoCentralFoam use fixedFluxPressure for walls -- for high speed compressible problems zero gradient is sufficient.
Caelan
Old   June 16, 2022, 01:08
Charles
Marpole is on a distinguished road
Hello Caelan,
I'm very interested in rhoReactingCentralFoam you developed 2 years ago. Is there any further development such as upgrading to a new version for OpenFoam v9?
Regards,
ET3 likes this.
Charles L.
Marpole is offline   Reply With Quote
Old   July 12, 2022, 14:49
Default rhoReactingCentralFoam
  #16
ET3
Erik T
ET3 is on a distinguished road
Charles,
Sadly, Caelen died earlier this year.
I too am interested in updating this solver. Have you tried doing so?
I am trying it right now and I am stuck. The updates to versions 8 changed things quite a bit. I'd be interesting in learning what you have tried and if you have success. I am new to this but so far it looks like there is more than a handful of changes and based on the threads you have been involved in, it seems like reactingFoam would be the replacement to rhoCentralFoam, but reactingFoam may not be the right solution for these problems.
ET3 is offline   Reply With Quote
Old   July 13, 2022, 23:37
Charles
Hi Erik,
Thanks for letting me know. I visited Caelan's website. What a loss!
I haven't started updating the program. Instead, I installed openfoam 7 and can run the program to address my immediate problem. It solved the problem though slow.
I tried, on openfoam 9, reactingFoam. It has everything I need but it cannot solve shock wave and supersonic speed flow. So not much useful.
Thanks again for letting me know.
ET3 likes this.
Charles L.
rhoCentralFoam transport equation JoaoDMiranda OpenFOAM Programming & Development 28 January 15, 2020 08:12
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 08:00
calculate a nozzle flow using rhoCentralFoam hg2lf OpenFOAM 0 October 25, 2012 21:26
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 21:08
laminar compressible solver for rhoCentralFoam (OF-2.0.x) turbulentwakes OpenFOAM Running, Solving & CFD 2 March 21, 2012 03:02
