Parallel running error (high performance computer)
Old   February 3, 2013, 11:35
Default Parallel running error (high performance computer)
Aathavan
Aadhavan is on a distinguished road
Hi Guys,
I am trying to use high performance computer for my case.
I am using MRFSimpleFoam, 5.5 million cells, 36 processors.
The case is running without any problem in my machine with 4 processors.
The same case I tryied to run many times in HPC but no success.
I tried different type of mesh as well, always its giving the error message as follows.
(I am struggling with this problem for last 3 days)
any help and suggestions are appreciated
Create time
Create mesh for time = 0
[34] #0 [35] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1. in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[34] #1[35] #1 Foam::sigSegv::sigHandler(int)Foam::sigSegv::sigHa ndler(int) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[35] #2 __restore_rt at sigaction.c:0
[35] #3 Foam:rocessorPolyPatch::updateMesh(Foam::Pstream Buffers&) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[35] #4 Foam:olyBoundaryMesh::updateMesh() in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[35] #5 Foam:olyMesh:olyMesh(Foam::IOobject const&) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[35] #6 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[34] #2 __restore_rt at sigaction.c:0
[34] #3 Foam:rocessorPolyPatch::updateMesh(Foam::Pstream Buffers&) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[35] #7 main in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[34] #4 Foam:olyBoundaryMesh::updateMesh() in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[34] #5 Foam:olyMesh:olyMesh(Foam::IOobject const&) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[34] #6 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/MRFSimpleFoam"
[35] #8 __libc_start_main in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[34] #7 main in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/MRFSimpleFoam"
[34] #8 __libc_start_main in "/lib64/libc.so.6"
[34] #9 Foam::UOPstream::write(char) in "/export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/MRFSimpleFoam"
[cnode-5-75:31459] *** Process received signal ***
[cnode-5-75:31459] Signal: Segmentation fault (11)
[cnode-5-75:31459] Signal code: (-6)
[cnode-5-75:31459] Failing at address: 0xa4300007ae3
[cnode-5-75:31459] [ 0] /lib64/libc.so.6 [0x30ab6302d0]
[cnode-5-75:31459] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x30ab630265]
[cnode-5-75:31459] [ 2] /lib64/libc.so.6 [0x30ab6302d0]
[cnode-5-75:31459] [ 3] /export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam18processorPolyPatch10updat eMeshERNS_14PstreamBuffersE+0x23e) [0x2b16d0e7bd4e]
[cnode-5-75:31459] [ 4] /export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam16polyBoundaryMesh10updateM eshEv+0x1b9) [0x2b16d0e80829]
[cnode-5-75:31459] [ 5] /export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam8polyMeshC1ERKNS_8IOobjectE +0xbad) [0x2b16d0ed0d2d]
[cnode-5-75:31459] [ 6] /export/home/sselvaraju/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam6fvMeshC2ERKNS_8IOobjec tE+0x19) [0x2b16cf866059]
[cnode-5-75:31459] [ 7] MRFSimpleFoam [0x41a47d]
[cnode-5-75:31459] [ 8] /lib64/libc.so.6(__libc_start_main+0xf4) [0x30ab61d994]
[cnode-5-75:31459] [ 9] MRFSimpleFoam(_ZN4Foam9UOPstream5writeEc+0xd1) [0x417709]
[cnode-5-75:31459] *** End of error message ***
mpirun noticed that process rank 34 with PID 31459 on node cnode-5-75 exited on signal 11 (Segmentation fault).
Thanks for your time and help,
Aadhavan
Aadhavan is offline   Reply With Quote
Running mapFields with Parallel Source and Parallel Target RDanks OpenFOAM Pre-Processing 4 August 2, 2016 05:24
parallel running openFoam-1.5-dev lulo OpenFOAM 3 October 3, 2011 11:42
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 15:52
Parallel running needs more iterations? zhernadi OpenFOAM Running, Solving & CFD 3 March 27, 2011 21:38
Error while running in PARALLEL Ravi Duggirala FLUENT 4 August 3, 2010 10:01
