Simulation for a bubble rising from the bottom of water
Old   February 8, 2013, 11:21
Default Simulation for a bubble rising from the bottom of water
Guifan Li
liguifan is on a distinguished road
Hi everyone,
Is there anybody can give me some hint on how to build up a model that can simulate the bubble rising in the water.
I can build up a sphere and a water container using Gmsh, however, I am not sure how to build up the water with Openfoam of Gmsh.
Any help will be appreciated!
liguifan is offline   Reply With Quote
Old   February 8, 2013, 15:22
Guifan Li
I have tried the damBreak and CapillaryRise case in the tutorials but they are all about liquid-air or liquid-liquid interaction. Haven't found any information relative to the bubble rising
Old   February 8, 2013, 15:34
Daniele Vicario
danvica is on a distinguished road
Why is the damBreak case not good ? If the bubble is made of air you are in the liquid-air case. Just use that case using a different setfields dict. If you need tomorrow i can send you an example...
Btw you don't need Gmsh for this.
Daniele Vicario
blueCFD2.1 - Windows 7
danvica is offline   Reply With Quote
Old   February 8, 2013, 15:44
Guifan Li
Hi Danvica,
Thanks for the reply! It sounds like I need to manipulate the setfields, which I am not too sure how to do, to create a spherical air space(bubble) within the liquid volume. Is that right?
If you can send me an example that would be great!
Although I need to extend it to a 3D case, this would be a good start.
Look forward to hearing from you!
Old   February 8, 2013, 16:12
Daniele Vicario
I will but maybe this post could help you: http://www.cfd-online.com/Forums/ope...tml#post330597
Daniele Vicario
Old   February 8, 2013, 23:07
Guifan Li
Hi danvica,
Thanks for the thread you gave me, I followed the two possible ways of making this working.
1) I tried to install the funckySetField from
http://openfoamwiki.net/index.php/Co...funkySetFields
but the download link seems not working anymore
I installed svn on my Ubuntu and did "
svn checkout https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Breeder_1.6/utilities/postProcessing/FunkySetFields/"
unfortunately, it said "couldn't open the requested SVN system"
2) I modified my setFieldsDict as
You can do that easily with setFields like
18 defaultFieldValues
19 (
20 volScalarFieldValue alpha1 0
21 );
22
23 regions
24 (
25 sphereToCell
26 {
27 centre (0.05 0.1 0.5);
28 radius 0.01;
29 fieldValues
30 (
31 volScalarFieldValue alpha1 1
32 );
33 }
34 );
on the thread you provided.
Then I do cp -r alpha1.org alpha1->setFields->interFoam
However, by using paraFoam to view the model, I only can see the square without any bubble or anything in it.
Please advice if I did anything wrong? Thanks!
Old   February 9, 2013, 02:55
Daniele Vicario
The setfieldsdict seems correct even if I usually set alpha=0 for air and alpha=1 for water.
In Parafoam you need to look for alpha field.
Daniele Vicario
Old   February 9, 2013, 12:21
Guifan Li
By following your suggestion, the simulation works. Like the pictures here.
The second one is just after the simulation starts, the bubble bursts. But in real case, the bubble will rise to the surface of the water before it bursts? Even I change the size of the bubble to very small, it still bursts.
Sorry I forget to tell your my email address is: liguifan@gmail.com.
Thanks for that.
File Type: png Screen Shot 2013-02-09 at 12.05.19 PM.png (18.3 KB, 50 views)
File Type: png Screen Shot 2013-02-09 at 12.05.10 PM.png (34.4 KB, 39 views)
Old   February 10, 2013, 03:17
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Looking at your picture, the BC seems strange. What do u use for BCs in your simulation?
duongquaphim is offline   Reply With Quote
Old   February 10, 2013, 15:42
Guifan Li
The boundary conditions are as follows
alpha1.org
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
leftWall
type zeroGradient;
rightWall
type zeroGradient;
lowerWall
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
frontWall
type zeroGradient;
backWall
type zeroGradient;
p_rgh
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
leftWall
type buoyantPressure;
value uniform 0;
rightWall
value uniform 0;
lowerWall
value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
frontWall
value uniform 0;
backWall
value uniform 0;
U
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
leftWall
type fixedValue;
value uniform (0 0 0);
rightWall
type fixedValue;
lowerWall
type fixedValue;
atmosphere
type pressureInletOutletVelocity;
frontWall
type fixedValue;
backWall
type fixedValue;
I modified the case to a 3D cube, but the same thing happens- bubble burst before it rise to the water surface. Even more wired, the liquid-water leaks out from one of walls-I think from letfWall. I am not sure where it goes wrong.
Kind regards,
James
Simulation of waves on a Water Surface Leech OpenFOAM Pre-Processing 27 May 22, 2015 01:19
About bubble size distribution simulation tchllc FLUENT 0 August 12, 2007 04:07
VOF-compression of air with rising water yavuz FLUENT 0 November 26, 2005 09:00
Hot gas bubble collapse in cool water William Palm FLUENT 1 April 20, 2005 10:53
sinulate bubble rising with VOF danny FLUENT 3 October 8, 2004 11:18
