sprayFoam flow and mixture formation
Old   February 14, 2013, 05:57
Default sprayFoam flow and mixture formation
André Zboralski
azborals is on a distinguished road
Hallo everyone,
I tried to calculate a case with inlet flow in a cyinder and injection (constant mesh, no piston moving). Therefore I used sprayFoam. I forced a velocity at the outlet and the inlet is zero gradient. At first the result looked really good, but later the iteration became very small because the velocity in one cell at the inlet surface rose to 800 m/s. I tried to run diffrent cases --> but always the same. I thought it could be a mesh problem, so I did checkMesh --> Mesh OK
can anybody help me!
azborals is offline   Reply With Quote
Old   February 14, 2013, 06:45
Robert
vainilreb is on a distinguished road
Hey,
how does the temperature in your domain behave before the time step decrease occurs? I've encountered severe problems with temperature divergence, pressure divergence, very high velocities and thus very small time steps followed by a crash of the simulation - I fixed this by deactivating time step adjustment and setting a fixed timestep.
Best regards,
Robert
vainilreb is offline   Reply With Quote
Old   February 14, 2013, 09:25
André Zboralski
>>Hey,
Best regards,
Robert
Hey,
the temperature was okay. Now, I fixed the time step adjustment too --> the temperature increased to 1.4e41. If I run a case with a simple box, one surface is inlet and an other is outlet --> it works. But in the special case I use a complex geometry (cyclinder and intake manifold of a combustion engine --> stl). Do you have an idea?
Best regards,
André
Old   February 14, 2013, 10:00
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
zero gradient velocity inlet condition!!!
you will never get that working.
try instead to specify the velocity at the inlet
niklas is offline   Reply With Quote
mesh size in Eulerian multiphase flow - liquid/solid mixture microfin FLUENT 4 December 23, 2016 13:55
Boundary Conditions for flow over a hot road (sprayFoam) vainilreb OpenFOAM Running, Solving & CFD 0 August 28, 2012 07:34
Modeling two liquid flow mixture hamideh FLUENT 0 June 13, 2011 10:44
Two Phase Flow - Microbubble Formation and Growth Fluent_Applications FLUENT 0 June 15, 2009 18:52
