codeStream in SetFieldsDict
Old   March 5, 2013, 10:28
Default codeStream in SetFieldsDict
physics1 is on a distinguished road
Hi Everyone,
Im trying to initalize a non uniform density region inside set fields using the codeStream command shown below:
defaultFieldValues
volScalarFieldValue rho 1
regions
sphereToCell
centre (0 0 0);
radius 1000;
fieldValues
#codeStream
codeInclude
#include "createRad.H"
code
volScalarFieldValue alpha1 10*e^(-rad/1000);
but when I run setFields i get
FOAM FATAL IO ERROR:
Loading a shared library using case-supplied code is not enabled by default
because of security issues. If you trust the code you can enable this
facility be adding to the InfoSwitches setting in the system controlDict:
allowSystemOperations 1
The system controlDict is either
~/.OpenFOAM/$WM_PROJECT_VERSION/controlDict
or
$WM_PROJECT_DIR/etc/controlDict
file: /home/adparo/Documents/MultiTest/multiTest2/system/setFieldsDict from line 10 to line 15.
From function functionEntries::codeStream::execute(..)
in file db/dynamicLibrary/dynamicCode/dynamicCode.C at line 81.
FOAM exiting
Is it possible to use codestream in setFields and if not is there another way to do this? Later on i need to initalize with multiple density regions on my mesh each with different densities.
physics1 is offline   Reply With Quote
Old   June 14, 2013, 10:58
xiaoweii
xiaow_g is on a distinguished road
Just follow the instructions in the error information:
adding to the InfoSwitches setting in the system controlDict(not the case controlDict):
xiaow_g is offline   Reply With Quote
codestream, setfields
setFieldsDict, alpha1, free surface, wigley kolloff OpenFOAM Pre-Processing 10 April 3, 2015 05:05
Change deltaT using codeStream whatsoever OpenFOAM Running, Solving & CFD 1 April 30, 2013 02:53
Using #codeStream to set initial field for parallel run Hisham OpenFOAM Running, Solving & CFD 7 June 25, 2012 09:48
Using codestream in controlDict pad OpenFOAM Running, Solving & CFD 0 April 11, 2012 03:59
Bogus setFieldsDict in damBreak4phase{,Fine} tutorial cases mwild OpenFOAM Bugs 1 August 10, 2010 09:36
