setFields -time <range> ?
Old   March 19, 2013, 04:48
Default setFields -time <range> ?
Neilson Whit
wolfindark is on a distinguished road
Dear All,
by using "setFields -time 0,20 " is it possible to give a same constant temperature value to some cells at every time step during 20 seconds?
I tried but does not work.
pleased if you could give some idea how can I do that?
best regards
wolfindark is offline   Reply With Quote
Old   March 19, 2013, 11:18
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
setFields will change fields that already exist, so all you could do with your command is apply the setFieldsDict commands to 0-20. If you want a source term during simulation, you'll have to either:
1. Program it into your solver
2. In 2.1.x, use the sources option
3. In 2.2.x, use fvOptions
mturcios777 is offline   Reply With Quote
Old   March 19, 2013, 18:53
Neilson Whit
thank you mutircios
i use OF2.1.1, buoyantBoussineqPimpleFoam solver.
By using sources option do you think i can determine a spherical volume inside the fluid region as a heat source?
regards
Old   March 20, 2013, 11:45
Marco A. Turcios
Yes indeed. I haven't used sources much so I'm not overly familiar with it, so you'll have to do some digging.
Old   April 29, 2017, 06:01
kokab
kokab is on a distinguished road
hi
I also want to use setFieldsABLDict to implement roughness in the channel, but the problem is that, by this command as a pre_processing it is just implemented for the first time step as an initial condition. but I want it to be the constant effect during the time. does anyone have idea about it?
kokab is offline   Reply With Quote
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
