so large Co!! why?
Old   April 3, 2013, 04:40
Unhappy so large Co!! why?
chaoqing min
nennbs is on a distinguished road
I am new for the of. why is my Co so large? it is about 10e290. The cells are divieded in x,y,z directions20 20 200); the velocity is z direction, 1m/s; the block is a square of cylinder and r=0.1m, l=1m.
Thanks millions.
nennbs is offline   Reply With Quote
Old   April 3, 2013, 05:12
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Can you post case files? Or at least checkMesh output.
alexeym is offline   Reply With Quote
Old   April 3, 2013, 05:33
chaoqing min
thank you at first.
the output as follows:
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.0005
Courant Number mean: 4.9449e+289 max: 9.70882e+289
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib64/libc.so.6"
#3 void Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::Field<Foam::Vector<double> >&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Vector<double> >(Foam::tmp<Foam::GeometricField<Foam::Vector<doub le>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
in "/home/ifas/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/icoFoam"
#11
#12 __libc_start_main in "/lib64/libc.so.6"
#13
at /home/abuild/rpmbuild/BUILD/glibc-2.15/csu/../sysdeps/x86_64/elf/start.S:116
Gleitkomma-Ausnahme
Old   April 3, 2013, 05:38
Alexey Matveichev
Maybe I was not clear enough but can you post case files? (0, constant, system folders). Also you can fun checkMesh utility and post output here.
Though it seems to be empty boundary condition somewhere.
Originally Posted by nennbs View Post
thank you at first.
Create time
Reading field p
Reading field U
Starting time loop
Time = 0.0005
#11
#13
Gleitkomma-Ausnahme
Old   April 3, 2013, 05:41
colinB is on a distinguished road
Be careful spoiler is following:
the courant number is defined as follows:
Co = (u * deltaT) / deltaX
with u being the velocity
delta T the time step
and delta X the cell size
Assuming you have a not moving/deforming mesh
deltaX is constant
Assuming further you turned off adjustableTimeStep,
deltaT is constant as well
Now using some mathematics:
To blow up your courant number your speed has to go up
And this is usually due to bad boundary conditions, bad meshing
wrong physical setting, you may choose
I hope I could contribute
regards
colinB is offline   Reply With Quote
03 april, 2013
Large Epsilon 3D lepsilon Main CFD Forum 0 July 10, 2012 10:43
[ICEM] Large and small cylinder with inner wall Far ANSYS Meshing & Geometry 5 March 27, 2012 07:56
Simulating small features on large models siw CFX 1 February 16, 2012 17:10
large vortex on outlet when gravity accounted for Alejandra Menchaca Phoenics 0 March 3, 2009 19:53
what happens if y+ is too large or too small Bo Jensen Siemens 12 February 19, 2003 23:31
