Boundary condition turbulentHeatFluxTemperature causes crash if yPlus is too low
Like Tree1Likes
  • 1 Post By jherb
Old   April 4, 2013, 14:28
Default Boundary condition turbulentHeatFluxTemperature causes crash if yPlus is too low
Joachim Herb
jherb is on a distinguished road
Using the solver buoyantBoussinesqSimpleFoam and the boundary condition turbulentHeatFluxTemperature at a wall causes a crash in the solver for T if the yPlus value is too low at this wall.
The reason is, that the gradient of T at that wall is calculated in OpenFOAM-2.2.x/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.C:
gradient() = q_/(Ap*Cp0*alphaEffp);
or
gradient() = q_/(Cp0*alphaEffp);
But alphaEffp is set in /OpenFOAM-2.2.x/applications/solvers/heatTransfer/buoyantBoussinesqSimpleFoam/TEqn.H as:
kappat = turbulence->nut()/Prt;
kappat.correctBoundaryConditions();
nut() is calculated at the wall by the wall function, e.g. in /OpenFOAM-2.2.x/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions/nutkWallFunction/nutkWallFunctionFvPatchScalarField.C:
        if (yPlus > yPlusLam_)
            nutw[faceI] = nuw[faceI]*(yPlus*kappa_/log(E_*yPlus) - 1.0);
Now if yPlus is too low, nut is 0 so the equation for the gradient divides by 0.
And obvious solution would be to use a coarser grid, but this does not make sense (the SST turbulence model is used, so there should be no lower limit on yPlus).
I also reported this at: http://www.openfoam.org/mantisbt/view.php?id=806
How to fix this problem?
wayne14 likes this.
jherb is offline   Reply With Quote
Old   January 2, 2014, 02:17
Peter
palmerlee is on a distinguished road
Hi, Joachim!
I don't know what alphaEffp is, but it couldn't be just turbulent. It could be alpha+alphat, by my guess, and alpha shouldn't be zero at the wall or anywhere else, also guessing.
palmerlee is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 06:16
No-slip condition for non-resolved boundary layer in open channel banks Lupocci Main CFD Forum 1 January 17, 2013 03:11
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
