decomposepar error
Old   April 16, 2013, 09:58
Red face decomposepar error
Auggie
Yanming Ding is on a distinguished road
Hello Foamers,
Now I am trying to do decomposepar .
The order is:
blockmesh
toposet
createpatch -overwrite
decomposepar
after this, the error appears.
--> FOAM FATAL IO ERROR:
size 3764160 is not equal to the given value of 216000
file: /home/...case.../0/ccz from line 18 to line 3811162.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/OpenFOAM/OpenFOAM2.1.1/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
I didn't meet the error before. but if I do this order:
blockmesh
toposet
snappyhexmesh -overwrite
decomposepar
Then it is OK.
Help!
Thanks.
Yanming Ding is offline   Reply With Quote
Old   April 16, 2013, 12:05
HECKMANN Frédéric
fredo490 is on a distinguished road
This problem often happen when your variables files (in the "0" folder for example) come from another mesh.
Then the mesh has N cells and your variables files have Y cells. The decomposition cannot find the corresponding cells and crash
To solve this problem, look at your "0" file and find the problematic file (you might also want to check the hidden files).
fredo490 is offline   Reply With Quote
Old   April 16, 2013, 12:08
HECKMANN Frédéric
The answer is in your post actually.
The "0/ccz" file has more cells than your actual cell number declared in the mesh.
Old   April 17, 2013, 02:38
Default Thank you for your help
Auggie
Hi,Frédéric
I think it is just the problem ,I'm trying ...
thank you for your help!
decomposepar
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
