passive scalar increases
Like Tree6Likes
Old   May 18, 2013, 13:02
Default passive scalar increases
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have written a passive scalar equation that should be used in a compressible solver like rhoCentralFoam but in each test case i use that the passive scalar (gas) itself and also its residuals increases during the run.
i thought its because of included rho but don't know how to remove rho from the equation because at least phi includes rho in it and the code doesn't accept dividing by rho.
how to overcome the situation of issue?
File Type: h gasEqn.H (698 Bytes, 18 views)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 21, 2013, 13:55
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
as we wrote the last weeks via PM I 'll share everything now with the other peoples.
I am not sure if its working with the "rhoCentralFoam" couse in the describtion there is a line that this solver works with central schemes. So I am not sure if that is working with my suggestions. Here are the steps building a new solver with a conserved scalar:
Create a new solver (example is a compressible sovler)
1. go into your $FOAM_RUN dictionary
2. go one folder back (cd ..)
3. create a folder
mkdir -p applications/solvers/compressible
4. switch into that folder
5. copy existing solver to that one
cp -r $FOAM_SOLVERS/compressible/rhoSimpleFoam scalarRhoSimpleFoam
Rename and rebuild the new solver
1. wclean
2. rename the rhoSimpleFoam.C into scalarRhoSimpleFoam.C
3. change the file Make/files
EXE = $(FOAM_USER_APPBIN)/scalarRhoSimpleFoam
4. wmake (you should compile everything now, if yes everything is okay)
5. wclean
Add new conserved scalar
1. create a new file (e.g. scalarEqn.H; here its ZEqn.H)
2. insert the following lines:
//-  Solving equation of conserved scalar (Z)
fvScalarMatrix ZEqn
            fvm::ddt(rho, Z)
          + fvm::div(phi, Z)
          - fvm::laplacian(turbulence->muEff(), Z)
ZEqn.relax();
ZEqn.solve(mesh.solver("Z"));
3. Create a new scalar field in createFields.H:
    volScalarField Z
        IOobject
            "Z",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
4. insert the eqn. into the solver; for that insert the following line into scalarRhoSimpleFoam.C
        // Pressure-velocity SIMPLE corrector
            #include "UEqn.H"
            #include "EEqn.H"
            #include "pEqn.H"
            #include "ZEqn.H"
5. wmake
6. finished
Congratulations
- a friend used my solver for prediction of a mixture of methan - air
- gives very good results, only weakness is the constant density. For that I build a new one with two different densitys (not tested).
In the attachment are pictures of my test case (laminar + turbulent).
The conserved scalar is between 0 and 1.
Hope that helps.
cfd.pipon likes this.
Tobi is offline   Reply With Quote
Old   May 21, 2013, 14:17
Ehsan
Hi Tobias
could you please have a look into rhoCentralFoamModified I have put in the above post?
	tmp<fvScalarMatrix> gasEqn
	 fvm::ddt(rho,gas)
             + fvm::div(phi, gas)
                -fvm::Sp(fvc::div(phi), gas)
                      - fvm::laplacian(turbulence->muEff(), gas)
	gasEqn().relax();
	gasEqn().solve(mesh.solver("gas"));
then this term(you told me before is for more stability) should be removed?
and also have a look into position of
#include "gasEqn.H"
in the .C code if its in appropriate position.
thanks.
Old   May 21, 2013, 14:20
Tobi's Avatar
Tobias Holzmann
the term for stabilisation dont have to be removed. In OF2.2.x you can activate that term in the fvSchemes file
bounded
For more details have a look into that post: http://www.openfoam.org/version2.2.0/numerics.php
In my opinion the problem depends on the centralFoam. I have no idea how that algo is working. So you should change to the rhoSimpleFoam.
Old   May 21, 2013, 14:35
Ehsan
my case is treansient so rhoSimpleFoam may not be appropriate for my case.
I also have used rhoPimpleFoam with the same problem(not be scalar between 0 and 1)
that term is necessarily have to be there?
could you have a look into rhoPimpleFoamModified?
Old   May 21, 2013, 15:27
Tobi's Avatar
Tobias Holzmann
okay for a transient solver you have to use the following conserved equation:
//-  Solving equation of variance of mixture fraction
fvScalarMatrix ZEqn
    fvm::ddt(rho, Z)
  - fvm::Sp(fvc::ddt(rho), Z)
  + fvm::div(phi, Z)
  - fvm::Sp(fvc::div(phi), Z)
ZEqn.relax();
With that code in the rhoPimpleFoam I get the results in the attachement.
Seems that everything is working fine.
Hope it helps
Have fun
Tobi
Old   May 21, 2013, 16:36
Ehsan
thanks.I'm testing it now.but residuals of scalar still are higher than other equations. isn't it wrong?
and should I also add "bounded" in fvSchemes for all terms in 2.2.0 like
ddt(rho, h)     bounded Euler;
or shouldn't?
Old   May 21, 2013, 16:38
Tobi's Avatar
Tobias Holzmann
with that code above you do not have to use bounded schemes. If you do so, you ll do it twice! Thats wrong.
The scalar must be between 0-1 or the value you use in the 0/Scalar file
Old   May 21, 2013, 17:32
Ehsan
Thank you dear Tobias.Its exactly between 0 and 1 now.
I didn't grasp what did that openfoam.org page say.
it says in line 8 that:
For transient solutions, it is usually better to implement only the fvm::div(phi, h) term
but under the divScheme{} dictionary it is saying:
Compressible solvers for transient problems generally use the PIMPLE algorithm, which supports partial convergence of intermediate iterations. The solution may benefit from the use of the bounded form of convection but, in such cases, the corresponding bounded time derivative must also be included
then should I add "bounded" for other terms in continuity,momentum and energy(not scalar parameter that has modified in the ZEqn.H code) also so that their boundednes be maintained better or not(they have included in the code of solver like rhoPimpleFoam also rhoCentralFoam)?
like the example:
ddtSchemes
    default         Euler;
if its required then my runs till now are not accurate or its not necessary?
what means at all!
thank you for a bit clarification.
wyldckat likes this.
Old   May 21, 2013, 17:45
Ehsan
and also I forgot to ask about its residual.only want to know does it has a specific reason or its ordinary and hasn't anything wrong.
the residuals of passive scalar are of order of .001 while others are lower,does it have any specific reason?
Old   May 22, 2013, 08:31
Ehsan
since the problem is resolved now,I put this answer by dear Tobias in private(by his permission),here so that someone needs now or in future knows more about what I asked:
normally you do not have to do that but you can do that in the fvSchemes if you have Problems with some variables.
Please note!
You are not allowed to Change the time Derivation to bounded couse then you would have it twice in the scalar equation.
If you wanna use a bounded scheme on "U" you should Change that in the div and ddt schemes but in the ddt schemes you have to write a new entry just for the ddt(rho,U) -> bounded or something like that
Hope it s clear.
It makes me happy to solve your Problem.
Keep foaming and good luck.
Tobi
Old   May 22, 2013, 13:47
Tobi's Avatar
Tobias Holzmann
for clearness - please note that I meant the following:
if you are using the bounded time derivation you are not allowed to set the d efault value to "bounded" couse the implemented scalar has this line explicit in the code.
For that you have to use default as standard and modify the other values:
ddt(rho,U) bounded ...
Otherwise if you want to set the default value to b ounded you have to remove the red lines
fvScalarMatrix ZEqn
     fvm::ddt(rho, Z)
  + fvm::div(phi, Z)
And insert the bounds into div and ddt
immortality likes this.
Old   May 22, 2013, 14:15
Ehsan
thank you for summary.
and what I haven't understood yet is that when we have to use a bounded term in both steasy and unsteady,compressible and incompressible cases? some more clarification is good.
Old   May 23, 2013, 06:57
Ehsan
Hi again before close the issue dossier!
when I used linear scheme for probably more accuracy it didn't get a good result(not good appearance and also higher than 1)
div(phi,gas) Gauss linear;
but in upwind worked well again.
the question is:why its so?!
Old   May 23, 2013, 07:15
Tobi's Avatar
Tobias Holzmann
[CODEdiv(phi,gas) Gauss linear;][/CODE]
That depend on the schemes. On my Homepage you can find a summary about that Topic (unfortunatelly only in german). But the grapics show everything I think.
http://www.holzmann-cfd.de/index.php...rische-schemen
Old   May 23, 2013, 07:21
Tobi's Avatar
Tobias Holzmann
Info about the added Lines: Sp(...)
-> http://www.cfd-online.com/Forums/ope...tml#post407482
Old   May 23, 2013, 08:18
Ehsan
thanks Tobias
related to vanLeer nothing has said but it has nice results,then what do you suggest for better accurate and physical results for passive scalar transport?
Old   May 23, 2013, 11:44
Tobi's Avatar
Tobias Holzmann
thanks Tobias
I always prefer 2. order schemes.
For the scalar I prefer
limitedLimitedLinear 1 0 1
Old   May 23, 2013, 14:45
Ehsan
thanks.
vanLeer isn't a second order scheme?
what do 1 0 1 refer to respectively in the scheme?
Old   May 23, 2013, 15:05
Tobi's Avatar
Tobias Holzmann
vanLeer is a second order scheme.
To prevent unphysical results (the only scheme which is not producing unphysical results is gauss upwind 1st order) you can use limited schemes and schemes that are bouding the values:
limtiedLinear 1
limitedLinear 0.33
limitedLinear 0 = linear
The number behind the name is the value of the lmiiter. If you set it to one you have full limited functionallity. If you set it to zero there is no limiting in the scheme so you have the normal linear scheme.
- first number is for the limiter function as befor
- the second one is the lower bouding value
- the third one is the upper bouding value
As you set your scalar between 0-13.54 you should write:
limitedLimitedLinear 1 0 13.54
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
passive scalar for carbon monoxide kraizy STAR-CCM+ 0 October 12, 2009 20:13
