icoFoam vs. pimpleFoam
Old   May 21, 2013, 06:15
Default icoFoam vs. pimpleFoam
Tobi's Avatar
Tobias Holzmann
I am working with OF for 3 years now and sometimes I get very interessting results or Problems.
I set up a very simple case:
- a pipe (Diameter 10cm and length 50cm)
- inside is a sphere with diamater 2cm
The Setup is: laminar flow with 0.05m/s
The interesting thing is:
- icoFoam is running without a Problem
- pimpleFoam decrease the timestep after t=0.0015s to 10^-10 and so on
I analysed the flow after that time and saw that I get big velocity and pressure gradients at the outlet. Otherwise icoFoam solves the case without a Problem - same bc and Setup.
Does someone knows why the differences appears between the solvers (pressure equation?)?
In my opinion it should be possible to solve that simple case with the pimple algorithm too, isnīt it?
It would be nice if there is a discussion on that effect.
Thanks in advance and for the help.
Tobi
Old   May 21, 2013, 08:16
Daniel Pielmeier
billie is on a distinguished road
It is probably a good idea to post your fvSolution files for both solvers. I guess you use the same numbers for pressure correction. How many outer correctors do you use for pimpleFoam and is the momentumPredictor turned on.
I also had problems with a decreasing time step using the pimple algorithm. Using the momentumPredictor as well as increasing nOuterCorrectors and nCorrectors did help a lot in that situation.
billie is offline   Reply With Quote
Old   May 21, 2013, 09:21
Tobi's Avatar
Tobias Holzmann
Hi Billie,
I used limitedLinear schemes in both solvers.
I am at work at the Moment but later I ll have a look at the Settings in the fvSolution file.
I ll update you (all) today evening.
Thanks for the first advice
Old   May 21, 2013, 10:34
Daniel Pielmeier
From a quick glance at the code for both solvers I understand it as the following. Using pimpleFoam (PIMPLE-loop) with nOuterCorrectors=0, momentumPredictor=on and the same values for nCorrectors like in icoFoam (PISO-loop) should be the same as using plain icoFoam. Correct me if I am wrong.
pimpleFoam vs simpleFoam vs pisoFoam vs icoFoam? phsieh2005 OpenFOAM Running, Solving & CFD 45 March 22, 2021 09:14
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H uli OpenFOAM Programming & Development 7 January 26, 2013 15:01
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
