motorBike tutorial won't run correctly with 2.2.x |
May 31, 2013, 09:42 |
Hey everyone,
I'm trying to run the motorBike tutorial with OpenFOAM-2.2.x, but it is not running correctly. I haven't changed anything in the directory and it gives the following error when executing the ./Allrun command: Code:
xargs: illegal option -- i usage: xargs [-0opt] [-E eofstr] [-I replstr [-R replacements]] [-J replstr] [-L number] [-n number [-x]] [-P maxprocs] [-s size] [utility [argument ...]] xargs: illegal option -- i usage: xargs [-0opt] [-E eofstr] [-I replstr [-R replacements]] [-J replstr] [-L number] [-n number [-x]] [-P maxprocs] [-s size] [utility [argument ...]] Code:
ls -d processor* | xargs -i rm -rf ./{}/0 $1 ls -d processor* | xargs -i cp -r 0.org ./{}/0 $1 Also looking at the mesh generation, the snappyHexMesh terminates with an error when executed alone: Code:
--> FOAM FATAL ERROR: Unknown file extension Valid types are : 6 ( bdf eMesh inp nas obj vtk ) From function edgeMesh<Face>::New(const fileName&, const word&) : constructing edgeMesh in file edgeMeshNew.C at line 45. FOAM exiting |
June 1, 2013, 00:23 |
Dan Kokron
Works for me on Fedora18
xargs --help Usage: xargs [-0prtx] [--interactive] [--null] [-d|--delimiter=delim] [-E eof-str] [-e[eof-str]] [--eof[=eof-str]] [-L max-lines] [-l[max-lines]] [--max-lines[=max-lines]] [-I replace-str] [-i[replace-str]] [--replace[=replace-str]] [-n max-args] [--max-args=max-args] [-s max-chars] [--max-chars=max-chars] [-P max-procs] [--max-procs=max-procs] [--show-limits] [--verbose] [--exit] [--no-run-if-empty] [--arg-file=file] [--version] [--help] [command [initial-arguments]] xargs --version xargs (GNU findutils) 4.5.10 Copyright (C) 2011 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Written by Eric B. Decker, James Youngman, and Kevin Dalley. Built using GNU gnulib version 25d7f3a59bfdc7aaca4a016f687826883a55bef3 |
June 2, 2013, 17:11 |
update? patch?
Mitchell Long
how would one go about updating or finding a patch to have more options for the xargs and other commands in general?
June 3, 2013, 08:10 |
#4 | |
Dan,
This is a problem with the version of the CGAL library in MacPorts. It prevents surfaceFeatureExtract from compiling properly. I will help you later this morning. Quote:
September 6, 2013, 04:33 |
eMesh
Therese
I've met the same problem. It is because i didn't write the correct name of the eMesh in snappyHexMesh.
Have a look at your case. |
motorbike, openfoam, openfoam 2.2.x, tutorial |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 16:01 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
InletOutlet boundary condition in motorBike tutorial | madad2005 | OpenFOAM | 2 | November 27, 2009 08:15 |
Can workbench and cfx run correctly on vista? | Sandam | CFX | 1 | December 2, 2007 16:32 |
Cannot run Tutorial 11, please help | Harendra | Siemens | 1 | November 21, 2005 06:14 |
