June 11, 2013, 07:05 |
Parallel Computing in a local network
Rep Power: 13 |
Hi dear FOAMers,
I want to use two computers in a local network in order to make my calculations in OpenFOAM 2.2 much faster. I wish to run the calculations from cfd4 on the machines cfd3 and cfd4, which both have 4 processors (cpu), that means I want to use 8 cpus for the calculation. By the way I got the names of the computers by typing hostname in the terminal. The operating system on both computers is Kubuntu 12.04. In order to run applications in parallel I followed the instructions given by http://www.openfoam.org/docs/user/ru...s-parallel.php . So I first of all wrote the file "decomposeParDict" in order to break up the geometry and the field of my calculation in 8 subdomains. Afterwards I have written the file machines. After creating the mesh and decomposing my mesh and field on cfd4 I typed mpirun -hostfile machines -np 8 sprayFoam -parallel > log & in order to get the process using the sprayFoam solver started. Unfortunately I get the following error: mpirun was unable to launch the specified application as it could not find an executable:
Executable: sprayFoam while attempting to start process rank 4. I know that process rank 0 to 3 belong to cfd4 and process rank 4 to 7 belong to cfd3, that means that he cannot find the executable on cfd3. Can anybody help me through this problem? I would be very pleased for any hint. Thank you very much in advance. best regards Ray Last edited by ray; June 12, 2013 at 06:02. |
June 28, 2013, 03:51 |
Luca Giannelli
Rep Power: 16 |
Hello Ray,
I had a very bad experience using OF on multiple machines so I started this thread. I was mixing architectures and eventually I gave up. But! If you go through the thread there is a lot of troubleshooting related to mpirun you may be lucky enough to find your problem by following wyldckat's suggestions. Hope it helps! |
June 28, 2013, 05:54 |
RDG
Rep Power: 15 |
Hi Ray,
As far as I know, to be able to run in a local network, you have to: 1. Have the OpenFOAM installed in all the nodes you are willing to use, or in a shared (nfs) unit. 2. Have your user load the OpenFOAM environment by default by adding source /path/to/foam_install_dir/etc/bashrc to your ~/.bashrc 3. Have passwordless login by ssh to the nodes. |
July 1, 2013, 10:00 |
Rep Power: 13 |
Hey guys thanks for your answer.
Dear onyir, could you please describe in more detail point 2. Where shall I add this line and to which directory should it refer? best regards ray |
July 1, 2013, 10:08 |
RDG
Rep Power: 15 |
Hi ray,
In order to use OpenFOAM, you have to load the environment by sourcing the configuration file. For example, if you have OpenFOAM-2.2.0 installed in your home directory, you'll have to do . /home/user/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc or source /home/$user/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc To do that automatically for your user, you have to add that line (updating your OpenFOAM installation directory and version) to the file /home/$user/.bashrc |
July 1, 2013, 10:13 |
Rep Power: 13 |
i found my bashrc file in the following directory:
cfd4@cfd4:/opt/openfoam220/etc$ So do i have to add source/opt/openfoam220/etc/bashrc in the first line of my .bashrc - file? best regards |
July 1, 2013, 10:16 |
RDG
Rep Power: 15 |
You can add that line at the end of your .bashrc
July 1, 2013, 10:19 |
Rep Power: 13 |
oh now I know what you mean, but I already had that line added
July 1, 2013, 10:23 |
#9 |
Rep Power: 13 |
i still get the same error:
mpirun was unable to launch the specified application as it could not find an executable: Executable: sprayFoam while attempting to start process rank 4. |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
