dsmcFoam : writing options : How to keep only field data ? Not Lagrangian |
June 24, 2013, 04:48 |
Rep Power: 12 |
Hi !
I am running dsmc simulation of a gas flow with dsmcFoam, and I would like to be able to have a better control over the outputs of the simulations. I want to write the macroscopic fields, and averaged fields at each writeTime (RhoN, RhoNMean, UMean, ...) and keep them for post-processing. BUT I do not need all the data included in the lagrangian folder (the properties of each simulated particle, 90% of the memory storage ) I just need this data for the last time step to be able to continue the simulation. The purgeWrite option does not suit me, as it erases ALL the data (macroscopic + lagrangian) Is there a way to do what I want ? Thanks for your help ! Sylvain |
August 18, 2013, 04:41 |
Carl
in Allrun.C,you can find the code
August 19, 2013, 05:05 |
Rep Power: 12 |
Thanks, I see the following line in the Allrun file for some dsmc tutorials:
runApplication reconstructPar -noLagrangian |
controdict, output data, purgewrite, write, write data |
External magnetic field data | Richard Lee | FLUENT | 7 | January 11, 2019 04:43 |
Writing Case and Data Files Using Journal/Scheme Files | svp | Fluent UDF and Scheme Programming | 0 | April 5, 2011 11:04 |
may i import flow field data to do particle track? | Hao | FLUENT | 8 | April 29, 2008 08:22 |
how 2 freeze 1 phase flow field & start lagrangian | KK | CFX | 5 | February 14, 2008 16:48 |
Writing a transient data fileld | ant | CFX | 0 | October 20, 2002 12:19 |
