Volume flow rate boundary condition in OpenFOAM
Old   July 4, 2013, 15:44
Default Volume flow rate boundary condition in OpenFOAM
India
mayank.dce2k7 is on a distinguished road
I am new to OpenFOAM and I facing problems in setting volume flow rate boundary conditions that varies with time.
I am doing a transient simulation on a single bifurcating tube. The inlet has time varying volume flow rate (velocity profile at inlet is time varying parabola). At one outlet I want the outgoing volume flow rate to be 0.52 times that of inlet and at the other outlet to be 0.48 times that of inlet at each time step. Also, velocity sometimes goes negative so it also encounters reverse flow.
Earlier I ran a steady state simulation using simpleFoam and groovyBC on the same geometry setting a steady parabolic velocity(not flow rate) profile at inlet. It ran with success. But when it comes to setting volume flow rate boundary condition using groovy I am facing trouble. Do I have to use "type" as "groovyBC" or change to "type" as "groovyFlowRateInletVelocity" for setting volume flow rate at inlet and outlet patches?
When I use "groovyFlowRateInletVelocity" it does not seem to recognize variable defined on remote patches like "yp@INLET=pos().y", now when I use 'yp' later to define expression on outlet it doesn't recognizes "yp" so how should I access variables from other patches in case using "groovyFlowRateInletVelocity"?
Can someone please tell me a way to go about in performing this kind of transient simulation?
P.S- I am not at all good with C++ so I am trying to implement BCs using groovy.
Regards,
Mayank
mayank.dce2k7 is offline   Reply With Quote
Old   July 4, 2013, 17:01
Daniel Pielmeier
billie is on a distinguished road
According to the http://openfoamwiki.net/index.php/Co...oam/README_2.x groovyFlowRateInletVelocity is discontinued.
As for the flow rate you can use type groovy and something like this:
velocity=flowRate/area()
Where flow rate is your desired flow rate and area() is the patch area. I don't know if there is a better way but something like this worked for me.
I have not used this feature myself but you should be able to access the other patches like you described above.
billie is offline   Reply With Quote
Old   July 5, 2013, 17:35
India
So I guess I need to provide more details on my case so that people can help.
Below are my case file and also I have attached an image of the geometry. But this time I am trying a steady steady state simulation using simpleFoam.
0/U
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0 0 0);
boundaryField
    INLET
     type                            flowRateInletVelocity;
     flowRateExpression       "0";
     flowRate         swak {
     expression "area()*0.3518"; // incoming volume flow rate from inlet based on mean   inlet velocity
            valueType patch;
            patchName INLET;
     value           uniform ( 0 0 0 );
    OUTLET1
flowRate swak {
variables "area1@INLET=area();";
            expression "-0.52*area1*0.3518"; // volume flow going out of domain from outlet 1
            valueType patch;
            patchName OUTLET1;
OUTLET2
flowRate swak {
variables        "area2@INLET=area();"; // going out of domain from outlet 2
            expression "-0.42*area2*0.3518";
            valueType patch;
            patchName OUTLET2;
    WALL
        type            fixedValue;
        value           uniform (0 0 0);
0/p
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    INLET
        type            zeroGradient;
    OUTLET1
      type            zeroGradient;
    OUTLET2
       type            zeroGradient;
    WALL
        type            zeroGradient;
ContolDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
libs ( "libOpenFOAM.so" "libgroovyBC.so" "libgroovyStandardBCs.so" "libswak4FoamParsers.so") ;
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         100;
deltaT          0.005;
writeControl    timeStep;
writeInterval   20;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions {
    initSwak {
        // needed to allow DataEntry to work
        type initSwakFunctionObject;
        region region0;
When I run the case I am getting following error in terminal:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model laminar
No field sources present
SIMPLE: convergence criteria
field p tolerance 1e-05
field U tolerance 1e-05
field nuTilda tolerance 1e-05
Starting time loop
Time = 0.005
swak4Foam: Allocating new repository for sampledGlobalVariables
--> FOAM Warning :
From function ConcretePluginFunction<DriverType>::exists
in file lnInclude/ConcretePluginFunction.C at line 111
Constructor table of plugin functions for PatchValueExpressionDriver is not initialized
--> FOAM FATAL ERROR:
Parser Error for driver PatchValueExpressionDriver at "1.7-11" :"field area1 not existing or of wrong type"
Context of the error:
- From dictionary:
Evaluating expression "-0.52*area1*0.3518"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
FOAM exiting
I know I have done some insanely stupid things but please guys help me understand my mistakes......This is a real learning opportunity for me.
Old   July 6, 2013, 00:46
India
ok, solved one problem the syntax in current version with swak4Foam has changed to <variable name> {<patch name>}=<expression> rather than <variable name>@<patch name>=<expression>
Old   July 6, 2013, 03:07
India
So I went ahead and changed the syntax and got a converged steady state solution. But I am not getting satisfactory results.
now my 0/U file looks like below but rest of the files remain same as posted above:
0/U
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    INLET
flowRate         swak {
            expression "0.3518*area()"; // incoming volume flow rate from inlet based on mean inlet velocity
            valueType patch;
            patchName INLET;
    OUTLET1
flowRate swak {
            variables "area1{INLET}=area();";
            valueType patch;
             patchName OUTLET1;
OUTLET2
flowRate swak {
            variables        "area2{INLET}=area();";
            expression "-0.48*area2*0.3518";
            valueType patch;
            patchName OUTLET2;
    WALL
        type            fixedValue;
The terminal shows following:
Time = 0.39
--> FOAM Warning :
From function ExpressionResult::getUniformInternal(const label size,bool noWarn)
in file ExpressionResult/ExpressionResultI.H at line 324
The minimum value 1.37739e-05 and the maximum 5.99827e-05 differ. I will use the average 3.66384e-05
--> FOAM Warning :
smoothSolver: Solving for Ux, Initial residual = 1.16172e-06, Final residual = 4.74177e-08, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 1.43494e-06, Final residual = 6.6445e-08, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 2.8996e-06, Final residual = 6.96369e-08, No Iterations 4
GAMG: Solving for p, Initial residual = 9.54405e-06, Final residual = 4.09708e-07, No Iterations 2
time step continuity errors : sum local = 8.50625e-10, global = 4.95172e-20, cumulative = 5.0987e-18
--> FOAM Warning :
--> FOAM Warning :
ExecutionTime = 2.16 s ClockTime = 2 s
SIMPLE solution converged in 0.39 iterations
Can somebody please explain me the meaning of these warnings, how they affect the solution and how to remove them?
Old   July 6, 2013, 13:20
Daniel Pielmeier
I don't think you need to use area () when you use the flowRateInletVelocity boundary condition as the value you specify is already the flow rate. So for this case you probably wont need the swak expression at all and you can use plain flowRateInletVelocity.
Old   July 6, 2013, 22:47
India
Hi Daniel,
First of all, thanks for your replies.
Yes, I can do it just by placing values. But my real aim is to perform transient simulation in which inlet flow field depends both on time and space coordinates of inlet patch. I find groovy/swak4Foam a good tool as it provides freedom of inputting flow fields in the form of expression which is generally required. It gave me good results in first place when I specified a parabolic inlet velocity profile at inlet but I don't know whats wrong with flowRateInletVelocity. Basically what I am trying to do is that I am imposing Poiseuille flow (2*Uavg*(R^2-r^2)/R^2))) at the inlet and imposing volume flow rate condition at outlet i.e on one outlet volume flow rate is 0.52 times that on inlet and on the other outlet it is 0.48 time the inlet. I modified 0/U a little:
0/U
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    INLET
       type            groovyBC;
     variables "r2=(pow(pos().x,2)+pow(pos().z,2));R2=area()/pi;para=-((R2-r2)/R2)*normal();";
     valueExpression "2*0.351*para"; //where 0.351 is the average velocity
    WALL
        type            fixedValue;
    OUTLET1
flowRate swak {
            variables "area1{INLET}=area();flow1= -0.52*area1*0.351;";
            expression "flow1"; // volume flow going out of domain from outlet 1 which 0.52 times that at inlet
            valueType patch;
            patchName OUTLET1;
    OUTLET2
flowRate swak {
            variables "area2{INLET}=area();flow2= -0.48*area2*0.351;"; // volume flow going out of domain from outlet 2 which 0.48 times that at inlet
            expression "flow2";
            valueType patch;
            patchName OUTLET2;
My 0/p file remains unchanged:
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    INLET
        type            zeroGradient;
    OUTLET1
      type            zeroGradient;
    OUTLET2
       type            zeroGradient;
    WALL
        type            zeroGradient;
I am getting following error and warnings:
Create time
Reading field p
Reading field U
Starting time loop
Time = 0.005
--> FOAM Warning :
The minimum value 3.51015e-06 and the maximum 1.85231e-05 differ. I will use the average 1.09453e-05
--> FOAM Warning :
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0267623, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.022866, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0548532, No Iterations 2
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 0.035612
Specified mass inflow : 0.0439753
Specified mass outflow : 1.32494e-05
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
First of all why is it referring 'mass inflow' since simpleFoam is a incompressible solver I am inputting volume flow rate and not mass flow rate. Second why there is a difference in inlet and total outlet flow rates.
Can somebody help me resolve it?
Old   July 7, 2013, 03:54
Daniel Pielmeier
Okay I did not read carefully your previous posts and there were some misunderstanding on my side.
I have to take a closer look at this but currently don't have the time. Maybe someone else can help you in the meantime.
Old   July 8, 2013, 11:47
India
I am trying to make my 0/U file as compact as possible. A new version is below:
0/U
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    INLET
       type            groovyBC;
    WALL
        type            fixedValue;
    OUTLET1
        flowRate swak {
            variables "phi1{INLET}=-0.52*phi;";
            expression "phi1"; // volume flow going out of domain from outlet 1 which 0.52 times that at inlet
            valueType patch;
            patchName OUTLET1;};
    OUTLET2
        flowRate swak {
            variables "phi2{INLET}=-0.48*phi;";
            expression "phi2"; // volume flow going out of domain from outlet 1 which 0.52 times that at inlet
            valueType patch;
My 0/p file and controlDict remains same as in numerous previous post
I am applying simple math:
Flow rate @ inlet= 0.52*Flow rate @ inlet on the patch outlet 1 + 0.48 times* Flow rate @ inlet on the patch outlet 2..........i dunno why its not working. Help please!
Mayank.
Old   February 21, 2014, 10:32
Default outflow u: flowRateInletVelocity (with negative value) p: zeroGradient ??
RB
rbaud is on a distinguished road
Sorry to dig up this thread, but have you been any further in your understanding of your problem?
I won't be really helpful, but I will ask you more questions:
I'm trying to figure out how to set properly an outflow with flowRateInletVelocity.
Are you sure of the boundary combination for "multiple" outflow (pointing out of the domain), knowing the inlet has been set with u: flowRateInletVelocity, p: zeroGradient):
Outflow:
u: flowRateInletVelocity (with a negative value, as the flow leave the domain).
p: zeroGradient?
Shouldn't at least one of the outflow be set with a fixedValue pressure / zeroGradient velocity?
Thanks for sharing your progress and experience,
Regards,
Remi
rbaud is offline   Reply With Quote
Old   March 31, 2014, 06:46
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
I am not sure, how good i understood your question.
the standard setting is;
0/U :
inlet
flowRate 2; // Volumetric/mass flow rate [m3/s or kg/s]
outlet
outlet
type zeroGradient;
For pressure:
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   April 29, 2014, 12:32
IZUNNA DAVID
Izunna is on a distinguished road
Hi Daniel,
0/U
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    INLET
       type            groovyBC;
    WALL
        type            fixedValue;
    OUTLET1
flowRate swak {
            valueType patch;
            patchName OUTLET1;
    OUTLET2
flowRate swak {
            expression "flow2";
            valueType patch;
            patchName OUTLET2;
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    INLET
        type            zeroGradient;
    OUTLET1
      type            zeroGradient;
    OUTLET2
       type            zeroGradient;
    WALL
        type            zeroGradient;
Create time
Reading field p
Reading field U
Starting time loop
Time = 0.005
--> FOAM Warning :
--> FOAM Warning :
FOAM exiting
I am just wondering if you were able to sort out the problem about inlet condition depending on time and space coordinates. I am facing a similar problem in which the inlet expands with time.It is a typical case of LNG pool spreading and evaporation which starts with a small area (circular) and increase with time.
I have a code to calculate the area at every time step.Thus, I either need to use the area to work out the mass flow rate and implement this at the inlet boundary or use the area to work out the velocity and apply this velocity only within the area (velocity outside the area will then be zero).
I do not know how to implement any of the above.Any help from you will be highly appreciated.Thank you boss
DAVID
Izunna is offline   Reply With Quote
Old   April 29, 2014, 12:37
India
You can use codedFixedValue boundary condition or swak4Foam to give any expression or perform calculation based on time and space coordinates. Search codedFixedValue in the forum to look for syntax and all.
Regards,
Mayank
Old   August 11, 2014, 20:16
Default known inlet pressure and flow rate, how to set BC?
  #14
Kai
ssboss is on a distinguished road
Originally Posted by sivakumar View Post
0/U :
inlet
outlet
outlet
type zeroGradient;
For pressure:
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
Thanks,
Sivakumar
Dear Sivakumar,
I need to do something like what you said, except my known BCs are:
-flowrate (mass or volume)
-inlet pressure
I basically need to find the resulting outlet pressure of flow going through different geometries, something like a nozzle, with a given inlet water pressure and volumetric flowrate. Currently, I am doing something like this:
0/U :
inlet
type fixedValue;
value uniform (3 0 0);
outlet
volumetricFlowRate -1e-3 //(m^3/s)
0/p:
inlet
type fixedValue;
value uniform 830;
outlet
type zeroGradient;
In theory I know my inlet velocity as well, which is why i set it equal to that value. But I read somewhere the BC for pressure and velocity are supposedly coupled, and there are restrictions in specifying them together? I was thinking maybe I need to use something like pressureInletVelocityOutlet that sort of BC? Can someone kindly direct me further? Much thanks
ssboss is offline   Reply With Quote
Setting mass flow rate boundary condition maysmech OpenFOAM 15 July 22, 2021 11:30
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
Corrected (Referred) Mass Flow Rate Boundary Condition ermuir CFX 1 November 20, 2012 17:11
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
