setting the correct format of nonuniform List<vector> for inlet in 0 Folder |
August 6, 2013, 08:12 |
Mohsen KiaMansouri
Dear All
I have some problem with the correct format of nonuniform List<vector> for my inlet boundary conditions for U in 0 Folder. I want to specify a nonuniform velocity for U at inlet for my LES calculation from my previous RANS calculations output. In nonuniform List<vector> we must specify only the U in the inlet faces like this: Code:
value nonuniform List<vector> 32 ( ( 0.125901997 0.138911426 0. ) ( 0.128139153 0.172775626 0. ) ( 0.126960248 0.211820379 0. ) ( 0.120514534 0.254806578 0. ) ( 0.107431941 0.30025211 0. ) ( 0.0867254138 0.346227229 0. ) ( 0.0579536967 0.390691847 0. ) ( 0.0212141946 0.431824267 0. ) ( 0.138057172 0.00678228773 0. ) ( 0.135565937 0.0201092884 0. ) ( 0.131116718 0.0328430161 0. ) ( 0.126068711 0.0451080948 0. ) ( 0.121914245 0.0576611347 0. ) ( 0.11977531 0.0717905611 0. ) ( 0.120108962 0.0890788361 0. ) ( 0.122550257 0.111073039 0. ) ( -0.461236358 0.508895934 0. ) ( -0.393406957 0.530447841 0. ) ( -0.32478264 0.541867137 0. ) ( -0.257232815 0.543873072 0. ) ( -0.192155391 0.537038386 0. ) ( -0.130680457 0.521705806 0. ) ( -0.0739541948 0.498558581 0. ) ( -0.0230022091 0.468220979 0. ) ( -0.802104294 0.0394048579 0. ) ( -0.788241446 0.116924562 0. ) ( -0.764009297 0.191374391 0. ) ( -0.73147279 0.261725157 0. ) ( -0.690910041 0.326776087 0. ) ( -0.642638564 0.385182768 0. ) ( -0.587392509 0.435639977 0. ) ( -0.526437223 0.477134943 0. ) ); so here is my question: how can I export my inlet from my previous RANS calculations at the inlet patch to have the above format (i.e. the values of velocities at inlet faces with the OpenFOAM Format) without the need for arranging them manually. since my inlet have more than 4000 faces so it is impossible to do it manually. I have used the sampling utility in inlet for my previous calculations but it gave me the values of velocities at points not cells. Does anybody know how can i do that? Thanks for your helps in advance.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
August 6, 2013, 17:00 |
Mohsen KiaMansouri
I found The Answer.
I write it here for the future use. The values for all the variables will be written for all the patches (including the inlet patch) in all timesteps (except 0 folders) in the same format that is needed for "nonuniform List<vector>" so I can easily copy them for 0 Folder. so there is no need for sampling utility. furthermore I found the answer to my question about sampling by reading the sampleDict headers in src. in order to sample the data on a surface the following code should be added to controlDict: Code:
surfaceSampling { // Sample at inlet type surfaces; // Where to load it from (if not already in solver) functionObjectLibs ("libsampling.so"); enabled true; outputControl outputTime; interpolationScheme cellPointFace; //cellPoint; //cell; surfaceFormat foamFile; //vtk; foamFile : separate points, faces and values file // Fields to be sampled fields ( U k epsilon ); surfaces ( Inlet_constant { type patch; patches ( inlet ); // interpolate true; HTRL If True then the point values will be given not cell values // Optional: whether to leave as faces (=default) or triangulate // triangulate false; } ); } } Code:
interpolate true Of course as I told before there is a simpler way and therefore no need to use the sampling utility in order to find the corresponding values that must be used with "nonuniform List<vector>" but the final results for both was the same.
August 9, 2013, 12:30 |
Rep Power: 12 |
hi, thanks for sharing your results.
I tried to apply the sample utility to the channel flow case, creating a sampleDict where I define a plane at a certain distance from the outlet: setFormat raw; surfaceFormat foamFile; formatOptions { ensight { format ascii; } } interpolationScheme cellPoint; fields ( p U ); surfaces ( constantPlane { type plane; basePoint (3 0 0); normalVector (1 0 0); } ); I run the solver, then I type: sample -latestTime and a directory called surfaces is created, where you can find: a file called faceCentres which has twice the number of cells (if I have a square grid of 4x4 cells, faceCentres has 32 values); a file called points where there's the list of the grid points coordinates (25 values if you have a 4x4 grid); files p and U containing twice the number of cells (32). What I think I have understood is that by the sample utility (and by the above sampleDict) I obtain values of p and U (and others if you want) at cell centres, not at points. I am trying to use this "sampled" files to feed another channel flow case at inlet by timeVartingMappedFixedValue, such as in pitzDailyExptInlet tutorial). The questions are: how do you manage to get a list of values for p, U, .... fields at a certain section (at inlet, outlet, or middle sections) without sampling utility? don't you need something like timeVaryingMappedFixedValue or groovyBC boundary patch type to set nonUniform list of values at inlet? thanks! |
August 9, 2013, 17:18 |
#4 | ||
Mohsen KiaMansouri
Dear KYPCK444
type fixedValue value nonuniform List<vector> Quote:
in this case i use a trick so that i will use timeVaryingMappedFixedValue or groovyBC type for my inlet then i will run my case only for 1 time step then I go to the new time step folder and continue just like that i said above. The reason for this is that because if I use timeVaryingMappedFixedValue or groovyBC for my inlet since they are a type not value then I can't use other inlet types like directMapped (at least I don't know how to use them simultaniously!!)
September 17, 2013, 07:39 |
Philipp
Rep Power: 26 |
Dear Kia,
But what, if the outlet of the source case does not have the same mesh as the inlet of the target case, i.e. meshes are not conformal? I can not just copy the "old" values to the "new" inlet, because number and location of each face differs... Philipp.
The skeleton ran out of shampoo in the shower. |
September 17, 2013, 15:55 |
Mohsen KiaMansouri
Dear Philipp
Yeah you are right.I dont know what to do if you want to use the outlet of you case for the inlet of your new case. Please let me know if you find something.
November 26, 2013, 02:59 |
#7 | |
sqing
I have found that most of the LES tutorials in OF set the inlet velocity as Code:
inlet { type turbulentInlet; referenceField uniform (10 0 0); fluctuationScale (0.02 0.01 0.01); value uniform (10 0 0); } Best regards sunxing |
April 28, 2017, 13:49 |
Hi everybody,
I'm trying to use my velocities in a plane within my channel as the inlet boundary conditions for my new case. I used the sample utility for extracting the data on the plane. I set the output style as foamFile. In my new case, I used the obtained data on the plane (from the previous solution) as follows: Code:
type fixedValue value nonuniform List<vector> 1200 ( . . . ); Do u have any idea why this happened?? Regards, Mostafa |
July 18, 2019, 08:03 |
#9 | |
Hardik Chauhan
Rep Power: 7 |
[DesignModeler] Airfoil Coordinate data Error inspite correct format | Bharath_S | ANSYS Meshing & Geometry | 0 | December 25, 2012 12:56 |
What is the correct date format? | surjamankhatiwora | Main CFD Forum | 0 | November 25, 2010 23:00 |
[PyFoam] setting is not correct? or not compatible with 1.6? | seasoul | OpenFOAM Community Contributions | 2 | March 23, 2010 11:42 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
