Relative roughness in openfoam
Like Tree8Likes
Old   August 28, 2013, 02:10
Vishal
inf.vish is on a distinguished road
Thanks.
I will have a look at the links.
Originally Posted by Mojtaba.a View Post
Right now I have found this article which is quite useful:
www.engmech.cz/2012/proceedings/pdf/195_Furst_J-FT.pdf‎
It uses openFOAM and a new turbulence model which is best for laminar turbulent transition modeling.
The link you mentioned above is not opening.
I do not want to go into the complications of LES since I will be using kOmegaSST only.
The problem i am facing now is that in the pitzDaily case does not show continuous vortices as it showed with LES. I am using kOmegaSST turbulence model. I am using wall functions and my flow has a very high reynolds number.
pitzDaily.zip
inf.vish is offline   Reply With Quote
Old   August 28, 2013, 05:21
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Check this link:
http://www.engmech.cz/2012/proceedin...Furst_J-FT.pdf
Have you set the right y+ values (Or in other meaning, first cell height) to the correct values?
Provided links has a comprehensive procedure to calculate first cell height.
Right now I am working on kkLOmega model which is best for capturing laminar turbulent transition.
I will report if I get anything useful.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   October 8, 2014, 17:07
Default les nut
  #23
kadan is on a distinguished road
Check this link:
Hi, I want to add skin roughness to my LES turbulent mode , is it possible? I found in LES mode the surface is smooth. How can I do that?
kadan is offline   Reply With Quote
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 12:25
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 16:52
[Gmsh] gmsh 2.6.0 conversion to OpenFoam 160 rosswin OpenFOAM Meshing & Mesh Conversion 0 March 5, 2013 07:34
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev OFU OpenFOAM Meshing & Mesh Conversion 0 June 16, 2010 04:36
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
