PorousSimpleFoam
Old   August 20, 2013, 09:29
Default PorousSimpleFoam
mohsen kh
m5m5kh is on a distinguished road
Hi dear friends
I have some problems with my case.I want to model a furnace as a porous medium with constant porosity of 0.5,so I modeled my case with Gambit and import it to OF using "fluent3dtofoam".then, I decided to modify my porous domain so I used "setSet"
I did these things in terminal
1. I define "porous.setSet" file and box (min X min Y min Z)(max X max Y max Z).
2. setSet -batch porous.setSet
3. setsToZones
4. finally I used my solver "myPorousSimpleFoam"
but it seems something is wrong with my simulation.I also don't know how to set porosity equal to 0.5 in "porosityproperties" file in constant folder.I'm not sure I set "e1" and "e2" properly.I look forward for your useful replies.
m5m5kh is offline   Reply With Quote
Old   August 21, 2013, 13:35
Goncalo Pedro
gonpe is on a distinguished road
Hard to tell what you mean by "something is wrong with my simulation".
e1 and e2 are the axis directions that define the coordinate system local to your porous media. Seems from the images that you should be able to align them to the cartesian coordinate system ((1 0 0) and (0 1 0)) for example) and set your coefficients in relation to that.
You need to set the Darcy Forcheimer coefficients that are applicable to your material. I suggest digging into some literature to find that.
Take a look at the angledDuct tutorials (porousSimpleFoam) for some help.
Goncalo
gonpe is offline   Reply With Quote
Old   August 25, 2013, 07:06
mohsen kh
Goncalo
Hi dear Goncalo
I want to know how should I set porosity of 0.5 for my case and what I should do to find a,b which are used for alpha and beta to define D and f in my porosityProperties file in my constant folder.
please see this thread
http://www.cfd-online.com/Forums/ope...ous-zones.html
where can I found these coefficients for sponge iron
Old   August 27, 2013, 18:31
Goncalo Pedro
Hi Mohsen
I've never tried to find porous media coefficients for that type of material, so can't help you on that specific point.
I typically find basic porous media info in engineering handbooks (simple weaves etc.). I haven't come across pig iron yet
I suspect you will need to do some digging into papers and material handbooks.
Sorry can't help you any more than that!
Goncalo
Old   July 28, 2017, 00:49
Default Possibly useful reference
RygeltheXVI is on a distinguished road
Hello All,
This Tech Report may prove helpful for those having difficulty understanding Darcy-Forchheimer settings in OpenFOAM.
Kind Regards,
RygeltheXVI
RygeltheXVI is offline   Reply With Quote
porousSimpleFoam aban OpenFOAM 10 July 20, 2022 03:01
Adding temperature equation to porousSimpleFoam David_010 OpenFOAM Programming & Development 9 February 14, 2018 01:22
porousSimpleFoam: oscillating velocity in the porous zone Se9a OpenFOAM Running, Solving & CFD 22 August 22, 2017 03:22
porousSimpleFoam - crash Sebaj OpenFOAM 2 January 4, 2012 16:16
What is the significance of the input vectors (e1, e2, d, f) in porousSimpleFoam bigbang OpenFOAM Running, Solving & CFD 4 July 22, 2011 11:31
