fireFoam combustion properties
Old   August 30, 2013, 05:21
Default fireFoam combustion properties
tobyB
tobyB is on a distinguished road
Could anyone help me find out where combustion properties are located in fireFoam? I am using oppositeburningpanels and can see that C3H8 has been used, and I do not seem to be able to find how they calculate or specify the heat released by combustion.
I also found a properties section for C3H8 in doxygen, it specifies rho, cp, and other things but not heat released.
Thanks
tobyB is offline   Reply With Quote
Old   September 3, 2013, 04:46
tobyB
Cp combustion seems to be specified with cp polynomial coefficients in thermo.compressiblegas, then using enthalpy of different products before and after the reaction to get heat released.
Ok, so I have now found that varliable dQ specifies the heat released (in J), however I need to try and sum this value over each cell in the volume to get the total heat release rate.
Does anyone know how to do this in paraview? I have tried integrate variables, but that seems to only give me values for a single cell.
Exporting the grid to excel and summing all dQ values works, but it is quite a slow process.
Thanks,
Toby
implementation of combustion in fireFoam 1.6-1.0 hz283 OpenFOAM 2 January 3, 2013 15:07
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Transport properties with PPDF combustion Erik Siemens 0 February 18, 2009 05:18
